ME3600 in release 15.4.3 flooding error messages
Hi fellas,
When I tried the latest me360x-universalk9-tar.154-3.S.tar image on a ME3600X it started to flood error messages, any of you fellas seen messages like these?
Nov 13 02:28:01.615: platform assert failure: (in_log_port_id > 0) && (in_log_port_id <= L3M_MAX_EFP_BD): ../src-nile/src-asic-nile/nile_adjmgr_l3m.c: 6193: add_l3m_efp_met
Nov 13 02:28:01.615: -Traceback= 7750C0z 28D03D4z 2A1BD20z 2A1C8C4z 2A1D6F4z 3420614z 3420BE0z 34213B8z 3426F6Cz 3427EFCz 348E470z 3489754z
Nov 13 02:28:01.615: -Traceback= 7750C0z 28D03D4z 2A1BD20z 2A1C8C4z 2A1D6F4z 3420614z 3420BE0z 3423210z 24AC584z D91034z D9ED28z 3F45BE0z 3F45D70z D9EE30z D91BE4z 24AC844z
Nov 13 02:28:07.227: platform assert failure: (in_log_port_id > 0) && (in_log_port_id <= L3M_MAX_EFP_BD): ../src-nile/src-asic-nile/nile_adjmgr_l3m.c: 6193: add_l3m_efp_met
Nov 13 02:28:07.227: -Traceback= 7750C0z 28D03D4z 2A1BD20z 2A1C8C4z 2A1D6F4z 3420614z 3420BE0z 34213B8z 3426F6Cz 3427EFCz 348E470z 3489754z
Nov 13 02:28:07.227: -Traceback= 7750C0z 28D03D4z 2A1BD20z 2A1C8C4z 2A1D6F4z 3420614z 3420BE0z 3423210z 24AC584z D91034z D9ED28z 3F45BE0z 3F45D70z D9EE30z D91BE4z 24AC844z
Nov 13 02:28:08.411: platform assert failure: (in_log_port_id > 0) && (in_log_port_id <= L3M_MAX_EFP_BD): ../src-nile/src-asic-nile/nile_adjmgr_l3m.c: 6193: add_l3m_efp_met
Nov 13 02:28:08.411: -Traceback= 7750C0z 28D03D4z 2A1BD20z 2A1C8C4z 2A1D6F4z 3420614z 3420BE0z 34213B8z 3426F6Cz 3427EFCz 348E470z 3489754z
Nov 13 02:28:08.411: -Traceback= 7750C0z 28D03D4z 2A1BD20z 2A1C8C4z 2A1D6F4z 3420614z 3420BE0z 3423210z 24AC584z D91034z D9ED28z 3F45BE0z 3F45D70z D9EE30z D91BE4z 24AC844z
Nov 13 02:28:09.043: platform assert failure: (in_log_port_id > 0) && (in_log_port_id <= L3M_MAX_EFP_BD): ../src-nile/src-asic-nile/nile_adjmgr_l3m.c: 6193: add_l3m_efp_met
Nov 13 02:28:09.043: -Traceback= 7750C0z 28D03D4z 2A1BD20z 2A1C8C4z 2A1D6F4z 3420614z 3420BE0z 34213B8z 3426F6Cz 3427EFCz 348E470z 3489754z
Daniel
Let me guess: you are using
Let me guess: you are using split-horizon group 0 in your config?
Aye, I do.
Aye, I do.
I'm stuck with multicasting
I'm stuck with multicasting problem, currently trying different setups. It seems that group 0 has some special use.
Are you running a L2 or L3
Are you running a L2 or L3?
Are running multicast in a VRF (Draft-Rosen) or in the global routing table?
The restriction I know of regarding the split-horizon-groups is a maximum attached EVC:s but I'm nowhere close to that number.
regards
Daniel
Combined, some services L2
Combined, some services L2 and multicast L3 with subscribers on L2 service instance. It works if i remove split-horizon group from service instances 400 and partly working (some interfaces do and some not) if i leave it, no matter the group number.
[code]
interface GigabitEthernet0/1 to 16
 switchport trunk allowed vlan none
 switchport mode trunk
 mtu 1504
 load-interval 30
 service-policy output PM_CLIENT_QOS
 service instance 1 ethernet
  encapsulation untagged
  l2protocol peer cdp stp lldp
  bridge-domain 8000 split-horizon group 1
 service instance 2 ethernet
  encapsulation dot1q 1000-1999
  bridge-domain 2 split-horizon group 1
 service instance 7 ethernet
  encapsulation dot1q 7
  rewrite ingress tag pop 1 symmetric
  bridge-domain 7 split-horizon group 1
 service instance 200 ethernet
  encapsulation dot1q 2000-2999
  bridge-domain 200 split-horizon group 1
 service instance 300 ethernet
  encapsulation dot1q 300
  bridge-domain 300 split-horizon group 1
 service instance 400 ethernet
  encapsulation dot1q 400
  bridge-domain 400 split-horizon group 1
interface GigabitEthernet0/17 to 22
 mtu 1504
 load-interval 30
  bridge-domain 7998 split-horizon group 1
  bridge-domain 22 split-horizon group 1
  bridge-domain 7 split-horizon group 2
  bridge-domain 201 split-horizon group 1
  bridge-domain 301 split-horizon group 1
  bridge-domain 402 split-horizon group 1
interface Vlan400
 vrf forwarding IPTV
 ip address 10.239.0.1 255.255.128.0
 ip pim sparse-mode
 ip igmp version 3
 load-interval 30
interface Vlan401
 vrf forwarding IPTV
 ip address 10.1.1.14 255.255.255.252
 ip pim sparse-mode
 ip igmp version 3
 load-interval 30
interface Vlan402
 vrf forwarding IPTV
 ip address 10.239.128.1 255.255.128.0
 ip pim sparse-mode
 ip igmp version 3
 load-interval 30
ip pim vrf IPTV rp-address 10.1.1.13
ip route vrf IPTV 0.0.0.0 0.0.0.0 10.1.1.13
[/code]
118
