Bronze
ME3600-X nile_dual_media_phy_set_one_feature() Failed to read MII_CONTROL for SFP PHY
Hi people,
we see this issue on one of our ME3600-X. I found this bug:
CSCub23041
Symptom:
My customers are seeing a "nile_dual_media_phy_set_one_feature() Failed to read MII_CONTROL for SFP PHY" error messages and ends up a old sfp's information is remained in "show inventry" log inspite of they has replaced it to other sfp in the same port.
Conditions:
unknown
Workaround:
reload
Fix is in 15.2(4)S1 but we had S2 running and error log was still there, and CPU usage is at over 80%.
Upgrade to 154-2.S did not help either.
We tried with one more reload but still the same. We could not find any logs that some SFP-s have been replaced before this issue.
Community Member
Hi smailmilakDid you resolved
Did you resolved this issue, I´m assuming is an SFP issue, I´m having the same problem.
Bronze
Hi, yes it was a SFP issue on
yes it was a SFP issue on port 1. Just remove it and everything should be ok.
Community Member
Just had same issue. Faulty
Just had same issue. Faulty SFP. Trashed it and problem gone.
587
