ME3600x IOS issue
After upgrade to 15.3(3)S  and on one switch with 15.3(1)S1  i got error
(config)#interface GigabitEthernet0/11
(config-if)#service-policy output qos-test
Qos: Out of tcam resources to execute command
QoS: Policy attachment failed.  Configuration exceeds hardware resources
for policy qos-test
#show logging
Nov 21 15:47:28: %QOSMGR-3-TCAM_EXHAUSTION: Internal Error in resource
allocation
bg-ba-m-1#show platform tcam utilization qos
Nile Tcam Utilization per Application & Region:
ES == Entry size == Number of 80 bit TCAM words
App/Region            Start  Num Avail  ES    Used Range  Num Used
QOS                   36864      4096   2
     nile0                                                       13
     nile1
for policy qos-test
#show logging
allocation
QOS                   36864      4096   2
     nile0                                                       13
     nile1                                                         6
1 ACCEPTED SOLUTION
Hi startx001 and LCC Data
Hi startx001 and LCC Data Networks,
This issue is related with TCAM resource exhaustion:
Issue the following command:
sh platform tcam utilization qos and see if you still have available entries to be used:
XXXXXXXXXX#sh platform tcam utilization qos
QOS 36864 4096 2
nile0 1802
nile1 1376
I had to ajdust QoS profiles to free space.
Hope this help you.
Hi startx001, hope you will
Hi startx001, hope you will be fine.
Did you a find a solution for this issue?
I'm facing same problem
This issue seems to arise
This issue seems to arise when matching any vlan (match vlan 1-4094) on a class-map. It does possibly sound like a bug, but I've now ameneded my class-map to match all traffic based on protocol instead  - this seems like it might work OK.
Class-map match-any class1
 Match protocol ip
 Match protocol ipv6
 Match protocol arp
 Match protocol cdp
QOS 36864 4096 2
nile0 1802
nile1 1376
Hope this help you.
Also got the same issue.
Could you please share the
Could you please share the below output:
- show platform tcam utilization all
- show platform tcam utilization qos
- show platform qos label structs
- show sdm prefer current
- show run
Please attach all the above outputs in a file. Also, could you please let me know how many vlans are there on the switch and if the service-policy is being applied on a trunk port.
Vinit
--VJ
I've now got a TAC case open,
I've now got a TAC case open, and the TAC engineer has managed to replicate the fault. I'm waiting to hear back. I've also attached the outputs here for information.
I started with a completely blank config, and applied the following to replicate the error:
class-map match-all voice
 match dscp ef
class-map match-any class1
 match vlan 1-4094
policy-map policy1-voice
 class voice
  priority
  police cir 4000000
   conform-action transmit
   exceed-action drop
policy-map policy1
class class1
  shape average 40000000
   service-policy policy1-voice
vlan 1794
int gi0/8
 switchport trunk allowed vlan 1794
 switchport mode trunk
 service-policy output policy1
QoS: Policy attachment failed.  Configuration exceeds hardware resources for policy policy1
1043
