Community Member
Metro ethernet support
Hi all,
I have the folowing scenario:
Two 7604 conected back-to-back with a WS-X6148-GE-TX module. the vfi show up the ldp neigbhor show up but the on the vc detail i have :
Destination address: 2.2.2.2, VC ID: 100, VC status: up
Output interface: none, imposed label stack {21}
Preferred path: not configured
Default path: active
Next hop: Invalid ADDR
Also the show mpls forwarding :
N-PE1#show mpls forwarding-table
Local Outgoing Prefix Bytes Label Outgoing Next Hop
Label Label or VC or Tunnel Id Switched interface
19 No Label l2ckt(100) 0 none point2point
21 Pop Label 2.2.2.2/32 0 Gi4/2 10.10.10.2
Thus this configuration is supported on this module or is there samething else with the configuration ?
Many thanks
1 REPLY
Hall of Fame Super Silver
Re: Metro ethernet support
it depends also how you have configured EoMPLS
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/pfc3mpls.html#wp1318682
If I understand correctly if you used an SVI VLan you need a WAN interface.
Is interface g4/2 a port on module WS-X6148-GE-TX ?
you see there is a valid complete entry for 2.2.2.2/32 via g4/2
Hope to help
Giuseppe
263
