This is what Verizon would like me to set up on my 3825 Router.
hostname xxxxx
interface GigabitEthernet0/0
description CPE_WAN
mtu 4470
ip address 157.130.x.x 255.255.255.252
duplex auto
speed 1000
media-type sfp
ip route 0.0.0.0 0.0.0.0 157.130.x.x
Please note, the Gigabit Ethernet0/0 is being used with other stuffs..not free.
My current T1 configuration
interface Serial0/2/1:0.1 point-to-point
description $FW_OUTSIDE$
bandwidth 1472
ip unnumbered Port-channel1.99
ip access-group 137 in
ip verify unicast reverse-path
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip nat outside
ip inspect SDM_MEDIUM out
ip virtual-reassembly
frame-relay interface-dlci 500 IETF
crypto map SDM_CMAP_1
ip route 0.0.0.0 0.0.0.0 Serial0/2/1:0.1
interface Port-channel1.99
bandwidth 1472
encapsulation dot1Q 99
ip address 65.x.x.x 255.255.255.224
ip access-group 138 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
How do I get this thing working? I'm totally in over my head with this. I was thinking of connecting the ethernet to one switch, and then create another vlan and set that interface to the ip address for WAN given by verizon. All routing will then be directed from interface serial0/2/1 to the interface on the switch. Am I even close??? Thanks
