Hi James,
This document explains how Packet over SONET (POS) interfaces on Cisco routers use the J1 byte in the SONET Path OverHead (POH) column to communicate information about the remote Path Terminating Equipment (PTE). The information contained in the J1 byte is displayed as the Path Trace Buffer (PTB) in the output of the show controller pos detail command.
http://www.cisco.com/en/US/tech/tk482/tk607/technologies_tech_note09186a0080094a7e.shtml
On some platforms,a router populates the PTB fields with information on the local interface, there is a problem with the POS link or nothing received from the remote interface.
Rate if it does,
Rgs.
