Password Recovery
The following commands are configured in a router.
username cisco password cisco123
line vty 0 4
login local
If i forget the username and password is there any way to telnet the router.The router is in remote place.The only thing i can do is telneting. Can we break the password??
Re: Password Recovery
You will need console access for breaking the password.
Since the router is in a remote place, your options are limited to doing a remote dialin into the router using a PSTN line modem.
That is if the router aux port is configured for remote dialin.
This link below may be of some help.
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_tech_note09186a0080094bbc.shtml
HTH-Cheers,
Swaroop
If you have another router in the remote place , there is another option if you know the enable password.
Connect the console port of the pwd router and aux port of the other router with a RJ-45 cable.
Do a telnet x.x.x.x 2001 ---- Now you should be login to the pwd router and if you know the second level , you can login to the router.
x.x.x.x -- router ip of the other router .
regards
vanesh k
126
