Community Member
PBR on ME3800x
Hello All ,
               I was trying to do this simple PBR on an ME3800 switch "15.2(2)S1" .
R2#sh route-map test
route-map test, permit, sequence 10
  Match clauses:
    ip address (access-lists): 10
  Set clauses:
    vrf VPN_A
  Policy routing matches: 99 packets, 9990 bytes
R2#sh ip access-lists 10
Standard IP access list 10
    10 permit (278 matches)
R2#sh run int te0/2
Building configuration...
Current configuration : 179 bytes
interface TenGigabitEthernet0/2
no switchport
mtu 9216
ip vrf receive VPN_A
ip address
ip policy route-map test
ipv6 address 2001:10:1:2::2/64
R2#debug ip policy dynamic
Dynamic PBR debugging is on
*Sep 16 20:31:40.841: IP: s= (TenGigabitEthernet0/2), d=, len 100, policy match
*Sep 16 20:31:40.841: IP: route map test, item 10, permit
*Sep 16 20:31:40.841: IP: s= (TenGigabitEthernet0/2), d=, len 100, set vrf
*Sep 16 20:31:40.841: IP: set vrf tableid 2
*Sep 16 20:31:40.841: IP: s= (TenGigabitEthernet0/2), d= (Vlan24), len 100, policy routed
*Sep 16 20:31:40.841: IP: TenGigabitEthernet0/2 to Vlan24
As you can packetes with the source of get matched , but the ping are fails . When I checked futher on the next hop router I have found that the packet gets normally routed and not tagged at all !!!.
*Sep 16 20:31:23.505: IP: s= (Vlan24), d=, len 100, input feature, MCI Check(85), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 16 20:31:23.505: IP: tableid=0, s= (Vlan24), d= (GigabitE
R4#thernet0), routed via FIB
*Sep 16 20:31:23.505: IP: s= (Vlan24), d= (GigabitEthernet0), len 100, dropped due to input interface drop feature
I have checked and found that this feautre is not supported on the ME3800x
Can any body confirm that PBR for VRF does not work correctly ?
Everyone's tags (3)
Community Member
PBR on ME3800x
Hello George,
On both platforms me3600/3800 neither VRF source selection nor PBR with "set vrf" are supported. So you are correct there is a limitation on these platforms.
Thank you
Best regards,
Dmitry Skotnikov
-- Best regards, Dmitry Skotnikov
