Community Member
Per VLAN traffic shaping on ME3400
Customer side Metro 3400 switch:
Port is 100Mb, Vlan 80 is 80MbCIR, Vlan81 is 10MbCIR
want to shape each vlan down to CIR
what is best configuration to do this? Here is what I tried...
class-map match-all vlan81
match vlan 81
class-map match-all vlan80
match vlan 80
policy-map ATTCIR
class vlan80
bandwidth 80000
class vlan81
bandwidth 10000
policy-map out-policy
class class-default
shape average 90000000
service-policy ATTCIR
IMC-OPTEMAN(config)#int gig0/1
IMC-OPTEMAN(config-if)#service-policy out
IMC-OPTEMAN(config-if)#service-policy output out-policy
QoS: Configuration failed. Match VLAN filter is not allowed in classmap of outpu
t policymap
I also try using access-lists and get the following:
access-list 180 permit ip any 192.168.128.0 0.0.0.255
access-list 181 permit ip any 192.168.100.0 0.0.0.255
match access-group 181
match access-group 180
policy-map ATTCIR
class vlan80
bandwidth 80000
class vlan81
bandwidth 10000
class class-default
Configuration Failed. Can not have ACL based classification in a class-map withi
n an output policy-map
1 ACCEPTED SOLUTION
Community Member
Re: Per VLAN traffic shaping on ME3400
This is a limitation of the 3400 Metro egress shaping granularity, which quite frankly is crap. You cannot shape to 80Mbps.
See this document:
http://www.cisco.com/web/DK/assets/docs/sp_me3400_IPTV.pdf
Please proceed as below, replacing the below sample with actual vlan data. Also you cannot use shaping and bandwidth/priority statement in the same policy map. So when you apply the output policy please remove the shape average from class default.
Do give a feedback how it goes.
Switch(config)# class-map in-class1
Switch(config-cmap)# match access-group 181
Switch(config-cmap)# exit
Switch(config)# policy-map in-policy
Switch(config-pmap)# class in-class1
Switch(config-pmap-c)# set qos-group 1
Switch(config-cmap-c)# exit
Switch(config)# class-map out-class1
Switch(config-cmap)# match qos-group 1
Switch(config)# policy-map out-policy
Switch(config-pmap)# class out-class1
Switch(config-pmap)# bandwidth
HTH-Cheers,
Swaroop
Community Member
thank you!
Your advice worked perfectly for marking the input traffic. Now I am unable to shape the output traffic the way I want. Since this is 100Mb FastEthernet interface the error message is that I can only shape to 50000000
here is config I want, and the 10000000 shaping works but ME3400 will not accept
80000000 class-based shaping on a FastEthernet interface
class-map match-all vlan81class
match vlan 81
class-map match-all vlan81out
match qos-group 81
class-map match-all vlan80class
match vlan 80
class-map match-all vlan80out
match qos-group 80
policy-map vlan80group
class class-default
set qos-group 80
policy-map vlan81group
class class-default
set qos-group 81
policy-map inputgroup
class vlan80class
service-policy vlan80group
class vlan81class
service-policy vlan81group
policy-map ATTOPT
class vlan81out
shape average 10000000
class vlan80out
shape average 80000000
You should be able to shape till the port speed (which is 100MB), have you assigned a lower bandwidth or speed on the interface.
HTH-Cheers,
Swaroop
Community Member
See this document:
3847
