Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
pros and cons of ethernet wan delivery handoff
I have been asked to put forth the pro & cons of a link when delivered as traditional SDH (OC3) and as ethernet services. Here ethernet would mean only the last handoff and the SP backend would still be SDH
I cannot think of any advantage except for the cost savings in buying a OC3 module if i go with ethernet option
are there any other risk and qos factors that i might need to consider
Ambi
1 ACCEPTED SOLUTION
Re: pros and cons of ethernet wan delivery handoff
we have used Enet over SDH a lot for various links (at 10, 100 and Gig speeds), and it is pretty good in general - the pipes are usually wire speed or close, and the kit benefits from SDH reliability.
couple of points:
if you get Enet over SDH for the pipe, then you probably get VC based bandwidth - you need to know what you have so you can limit your traffic to stay inside the rate unless the pipe is "qos aware" - a lot of the SDH GFP kit doesnt seem to be, or the SP doesnt turn that on.
you probably want to know if the SDH is on 1 or more paths, and what happens under fault conditions - you might lose maybe 50% of the capacity.
1 advantage is that it is Ethernet - you can use a switch rather than a software based router at the end of the link.
We had some problems with 100 Mbps as using SDH it is often set up as 2 VC-3s, giving only 97 Mbps. If you overdrive the Ethernet link, then since the SDH doesnt understand QoS that gives some problems. Rate limit the end points and it works very well.
am I to understand that we are talking about the "local loop" being delivered as MetroE versus POS?
if I not confused and this is what you are talking about then the major drawback we have seen in the ethernet handoff is the lack of QoS offerings from the SPs on ME that we are getting from the same SPs on our POS interfaces.
oopps, meant for this to be in the last message.
Under the heading of "DUH", MetroE as a local loop handoff allows us to scale up bandwidth as needed without the typical long provisioning cycle/process by the SP and without the additional of new cards, routers, network redesign, etc everytime we need a BW upgrade...Major reason we deploy MetroE as our access....
Our service is more of a ethernet over SDH.
The provider has installed a mux in our premises and runs a fiber SDH backbone. But he gives us a ethernet handoff to connect to our router. So anytime we need an upgrade the provider needs to provision the circuit but the only thing that is not needed is the interface cards on our routers
Ambi
couple of points:
OK - 1 other issue.
Ethernet has MAC frame overhead. So 10 Mbps of IP on Ethernet is less than 10 Mbps of a PoS pipe...
Thanks for the inputs stephan
Ambi
911
