Community Member
SFF8472-3-THRESHOLD_VIOLATION on ME-3800X
Hi All,
Please see the logs below on Cisco ME-3800X, We are using IOS  "me380x-universalk9-mz.153-2.S.bin"
%SFF8472-3-THRESHOLD_VIOLATION: Gi0/8: Rx power low warning; Operating value: -20.3 dBm, Threshold value: -19.0 dBm.
is this bug ?anyone encounter this error ?
Please help on this.
Regards.
Community Member
Similar symptoms are in Cisco IOS Release 15.1(3)S5 but it was resolved
CSCtu42387
Symptoms: Gigabit and 10 Gigabit Fiber link reporting threshold violation alarm in Cisco ME3600, Cisco ME3800, and Cisco 7600 devices. The "%SFF8472-3-THRESHOLD_VIOLATION: Gi0/11: Rx power high alarm" error message is seen on ports.
Conditions: This symptom is observed on Cisco ME3600, Cisco ME3800, and Cisco 7600 devices. The messages are seen with the interface shut or no shut.
SFF8472-3-THRESHOLD_VIOLATION Gi5/1: Rx power low alarm; Operating value:
-28.5 dBm, Threshold value: -24.0 dBm
Workaround: Fixing the fiber signal issue or disconnecting the fiber from the transceiver has been known to stop the messages
Community Member
Similar issue has been tracked under defect mentioned above CSCtu42387, but the fix has been integrated into 15.3(2)S build.
I would suggest you to try to reseat an SFP and verify if the message will clear.
Thank you
Best regards,
Dmitry Skotnikov
-- Best regards, Dmitry Skotnikov
1825
