Trunk port does not work in ME3400
Hi all, is there any cause so that a switchport mode trunk command does not work in a 3400 switch fast ethernet port? When I apply the command, and I define the vlans that should pass the trunk, and allow them, all of them fall. On the contrary, if I set the switchport access vlan XX command on the port, only that vlan works....but no idea why the trunk mode is not set...
The IOS is MetroBase 12.2(25)EX1
Re: Trunk port does not work in ME3400
Try specifying the port-type.
interface fastethernet0/1
port-type nni
For more information take a look at the following url:
http://www.cisco.com/en/US/docs/switches/metro/me3400/software/release/12.2_25_ex/command/reference/cli1.html#wp4847691
-W
Silver
You should be able to use trunks on both UNI and NNI ports.
switchport trunk allowed vlan X
those two commands should be enough.
Also, EX1 is an older IOS.
(44)SE is the current version.
334
