Bronze
VPLS QUESTION
Hi everybody
I hope everybody is doing fine.  Learning VPLS implementation on cisco, I have a few questions for you guys , I can not perform this lab in GNS3, and the books  I have been reading do not address these questions.
PE1
interface FastEthernet4/2
no ip address
 switchport
switchport access vlan 111
l2 vfi cust-one manual
vpn id 1
neighbor 10.100.100.2 encapsulation mpls
neighbor 10.100.100.3 encapsulation mpls !
interface Vlan111
no ip address xconnect vfi cust-one
1) Let say PE1 above receives a frame, it is untagged on f4/22,
PE1 notices that port is a part of vlan 111, PE1 therefore looks up MAC table for vlan 111, PE1 determines that frame need to be forwarded out on a PW,
My question is ::Will PE 1 add Vlan tag 111 before forwarding out that frame on a PW ?
2) May  i say every time a frame needs to be sent out of PW defined under " interface vlan xx", Vlan tag XX is added to the frame ?
Have a great day.
i
1 ACCEPTED SOLUTION
1) no, vlan111 is a part of
1) no, vlan111 is a part of the  vfi that is indipendent in this case from local vlan
for example you can use vlan111 - pe1 ---- pe2 -- vlan112 and this works correctly
2) yes, because the tag is applied on local side on all trunk that you want
regards
1 REPLY
regards
108
