WIC ADSL
I´m wondering if somebody knows about the maximum UPSTREAM rate that i can get using a WIC-1ADSL.
According to the ADSL standar the upstream rate is up to 1024 kbps, but I´m just gettin 832 kbps.
thanks and regards,
Re: WIC ADSL
hi
Can u confirm in which router you have this card installed and also do u have any idea about to which DSLAM you are getting connected using this connectivity ?
sometimes its possible to have some kinda of rate-limit applied for particulr profile to check that it shuldnt exceed the configured value of B/W.
also confirm whether you are subscribed for the whole 1024K ?
are you trying to upload some files or docs to the other site and checking hte upstream value ?
if yes whts the kinda connectivity or the amount B/W being used in the other end ?
regds
Re: WIC ADSL
I´m using a 1721 Router. The DSLAM profile is set to 1024kbps Upstream and Downstream.
When I use the command show dsl interface atm0, the rate recorded is of 1024 kbps downstream and 832 kbps upstream. It seems that this is the maximum value that the WIC-1ADSL can support for Upstream BW.
regards
147
