4-port GE WAN card in OSR
it said that 4-port GE WAN card supports ethernet over MPLS using 802.1q VLAN. here i wonder if OSR here is a PE router only. in other word, there is no additional router ( CE) needed?
thanks
difei
Re: 4-port GE WAN card in OSR
That's right - no additional CE router is required. You can transport end-station-attached servers/workstations/other-network-devices on L2 via an EoMPLS tunnel using this OSM card.
assuming MPLS VPN and using WAN connection, POS interfaces between OSR and GSR. Ps clarify:
1. there should be p2p connection type. in other word, one POS port on OSR only connects to a port on GSR.
2. if there are hundreds of edge area, the limitation should be the amounts of POS interfaces on GSR? assume the traffic volume is very low.
thanks
difei
312
