Community Member
7206 VXR Bootflash
Hi Guys,
Is it recommended to have a bootflash of ver 12.3 and IOS of 12.4??!?!
secondly does anybody knows if it's possible to upgrade the size of bootflash for NPE-400/2FE?
While I've 8MB of bootflash and running 12.3 but I cant load any recent 12.4 hence all bootflashes are larger than 8MB for recent IOSes!!
Re: 7206 VXR Bootflash
Reich, Boot Image is not directly co-related to the IOS version. For 7200 you will have boot images like boot.mz, kboot.mz, mboot.mz, verify it using dir bootflash:.
The existing boot image used with 12.3 will work with 12.4 as well if you have not added any new or unsupported PA. Verify the compatibility using this link.
http://www.cisco.com/en/US/products/hw/routers/ps341/prod_installation_guide09186a00805e7d4d.html
And yes you can store your larger boot image on a external device like you disk0: by using the command "boot bootldr disk0:.
The link given should be of help.
HTH-Cheers,
Swaroop
Community Member
Thx swaoop,
I'll give it a try!!!
bye
225
