Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
7507 VRF and CEF/Fast Switching
I'm running into a problem with a 7507 router running 12.4 where any vlan subinterfaces inside a VRF is being process switched instead of CEF or fast switched. I've verified that the source and destination addresses are valid in the cef FIB but for some reason it's falling back to process switching. Any ideas?
I've attached the config and the output of all the show commands I can think would be related.
For a test instance, packets from source 10.1.25.5 traveling to 216.82.160.42 are process switched, as are packets from 192.168.0.35 to 10.1.27.42.
Bronze
Re: 7507 VRF and CEF/Fast Switching
Depending of which 12.4 version you are running, you should have a look at this bug:
CSCsd00206: "Packets Are getting process switched instead of cef or fast switching"
First Found-in Version: 12.4,
12.4(5.13)T02
Bjornarsb
I'm running the newest 12.4(13b). According to bugtracker it looks like it's supposed to be fixed in 12.4(7.17)T and 12.4(7.17)M, is my understanding correct that the 12.4M fixes would be incorporated into 12.4 mainline?
Cisco IOS Software, RSP Software (RSP-JK9O3SV-M), Version 12.4(13b), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 25-Apr-07 06:26 by prod_rel_team
158
