Basic MPLS , IGRP - Confused about Basic Routing Process
Hello Forum
As a beginner in mpls i am confused about the differnt routing processes.
In a lab we have 4 Backbone (MPLS speaking) 6509.
- Basic routing process is ospf where all the links between this boxes are in.
Configuration 1 6509 see below.
=>>> Where is the connector from the basic routing to the mp-bgp ? no redistribution ist configured. ist that somwhrer "implicit" ?
(Lab is working, but no one understand it )
ip vrf VPN_A
rd 65000:1
route-target export 65000:100
route-target import 65000:100
ip vrf VPN_B2
rd 65000:22
route-target export 65000:22
interface Loopback0
ip address 10.10.2.2 255.255.255.255
router ospf 100 vrf VPN_A
log-adjacency-changes
redistribute bgp 65000 subnets
network 10.0.27.1 0.0.0.0 area 0
network 10.0.28.1 0.0.0.0 area 0
ip vrf VPN_A
rd 65000:1
ip vrf VPN_B2
rd 65000:22
mpls label protocol ldp
interface Loopback0
router ospf 1
router-id 10.10.2.2
network 10.0.12.2 0.0.0.0 area 0
network 10.0.24.1 0.0.0.0 area 0
network 10.10.2.2 0.0.0.0 area 0
router bgp 65000
no bgp default ipv4-unicast
no bgp default route-target filter
bgp log-neighbor-changes
neighbor 10.10.1.1 remote-as 65000
neighbor 10.10.1.1 update-source Loopback0
neighbor 10.10.3.3 remote-as 65000
neighbor 10.10.3.3 update-source Loopback0
neighbor 10.10.4.4 remote-as 65000
neighbor 10.10.4.4 update-source Loopback0
neighbor 10.10.5.5 remote-as 65000
neighbor 10.10.5.5 update-source Loopback0
neighbor 10.10.6.6 remote-as 65000
neighbor 10.10.6.6 update-source Loopback0
address-family vpnv4
  neighbor 10.10.1.1 activate
  neighbor 10.10.1.1 send-community extended
  neighbor 10.10.3.3 activate
  neighbor 10.10.3.3 send-community extended
  neighbor 10.10.4.4 activate
  neighbor 10.10.4.4 send-community extended
  neighbor 10.10.4.4 route-reflector-client
  neighbor 10.10.5.5 activate
  neighbor 10.10.5.5 send-community extended
  neighbor 10.10.6.6 activate
  neighbor 10.10.6.6 send-community extended
  neighbor 10.10.6.6 route-reflector-client
exit-address-family
address-family ipv4 vrf VPN_SER1
  redistribute ospf 50 vrf VPN_SER1
  no synchronization
exit-address-family
address-family ipv4 vrf VPN_B2
  redistribute connected
  no synchronization
exit-address-family
address-family ipv4 vrf VPN_A
  redistribute ospf 100 vrf VPN_A
  no synchronization
exit-address-family
router ospf 1
router-id 10.10.2.2
- BGP with adress families for the vrf's
router bgp 65000
exit-address-family
  no synchronization
exit-address-family
  no synchronization
exit-address-family
  no synchronization
exit-address-family
Thanks for help !
Martin
1 ACCEPTED SOLUTION
martin,
In order for BGP to form peering it needs to know the neighbor ip addresses right? so you achieve that layer 3 connectivity via some IGP when you have a couple of routers. Of course if they are directly connected then  its not necessary to run IGP( depends on how u peer).
BGP is needed for MPLS VPN's between the PE's as its the routing protocol to carry the VPNv4 routes which is an address family which is not your normal ipv4.
for the PE-CE, its up to you to choose whichever routing protocol you want RIP,ospf, BGP etc
Hope this helps
Kishore
Hi Martin,
this is the MP-BGP snippet:
exit-address-family
try to check 'sh ip bgp neighbor' - you'll see the address-families negotiated.
HTH,
Ivan.
Hi Ivan
This will be the output:
bl1s101#sh ip bgp neighbors
bl1s101#
Did I understand you correct ?
Regards, Martin
Hi Martin,
sorry my bad, you don't have IPv4 AF negotiated, you better look at:
sh ip bgp vpnv4 all neighbors
Ivan.
Thanks again,
here my output.
bl1s101#sh ip bgp vpnv4 all neighbors
BGP neighbor is 10.10.1.1,  remote AS 65000, internal link
  BGP version 4, remote router ID 0.0.0.0
  BGP state = Active
  Last read 2w6d, last write 2w6d, hold time is 180, keepalive interval is 60 seconds
  Message statistics:
    InQ depth is 0
    OutQ depth is 0
                         Sent       Rcvd
    Opens:                  0          0
    Notifications:          0          0
    Updates:                0          0
    Keepalives:             0          0
    Route Refresh:          0          0
    Total:                  0          0
  Default minimum time between advertisement runs is 0 seconds
For address family: VPNv4 Unicast
  BGP table version 88, neighbor version 0/0
  Output queue size : 0
  Index 2, Offset 0, Mask 0x4
  2 update-group member
                                 Sent       Rcvd
  Prefix activity:               ----       ----
    Prefixes Current:              31          0
    Prefixes Total:                 0          0
    Implicit Withdraw:              0          0
    Explicit Withdraw:              0          0
    Used as bestpath:             n/a          0
    Used as multipath:            n/a          0
                                   Outbound    Inbound
  Local Policy Denied Prefixes:    --------    -------
    Total:                                0          0
  Number of NLRIs in the update sent: max 0, min 0
  Address tracking is enabled, the RIB does have a route to 10.10.1.1
  Connections established 0; dropped 0
  Last reset never
  Transport(tcp) path-mtu-discovery is enabled
  No active TCP connection
Sorry about my bad understanding but I can still not make the relationship between basic IGP Routing . OSPF 1 and the MPLS, MP-BGP.
Martin
Hi Martin,
For MPLS VPN's there are 3 things you need.
1. IGP- This is used between the PE-P-PE routers for full connectivity so that you can run bgp later on
2. BGP- for MP-BGP tranport safi
3. PE-CE routing protocol- could be ospf bgp, rip,eigrp etc
in your case ospf 1 is used as the tranport IGP which i mentioned in point 1.
router osp 50, 60 and all are used as PE-CE routing protocol
Does this help ? Let me know if u need more info
Kishore
Hi Kishore
Thank you - yes that helps.
What I still not understand ist HOW the BGP will learn the connectivity from the IGP ?
Other than with PE-CE there is no Redistribution.
Or I am totally false and there is no need for BGP to knowing that ?
Martin
martin,
Hope this helps
Kishore
Thank you!
Martin
694
