%BGP-3-INVALID_MPLS
I received this error message in the log file of a BGP RR. I found the below bug CSCei83160 in cisco.com. However, there is no PIM running in my router. Anyone can advise ?
thanks
Re: %BGP-3-INVALID_MPLS
This is the description of the bug, kindly elaborate further:
Conditions: This symptom is observed on a Cisco router and is not
platform-dependent. The symptom occurs when a VRF instance is configured with
BGP as the Exterior Gateway Protocol (EGP).
Workaround: There is no workaround. (you'll have to change your code)
http://www.cisco.com/en/US/products/sw/iosswrel/ps1829/prod_release_note09186a00803c2609.html
HTH,
Mohammed Mahmoud.
Hi,We had a similar issue
We had a similar issue with below Logs & Label 3 being assigned.
09:06:30.610: %BGP-3-INVALID_MPLS: Invalid MPLS label (3)
             received in update for prefix 1xxx:123:10.0.0.0/8 from w.x.y.z
Only to find that auto-summary was enabled under customer vrf address-family. This was negated & resolved the problem.
Could you please provide us with the full message from the log.
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Jul 27 11:06:30 MYT: %BGP-3-INVALID_MPLS: Invalid MPLS label (3)received in update for prefix 65000:1:172.18.4.164/30 from 172.18.255.2
If you observe what is happening here is.
The cause for this log message is that you have configured EBGP as you PE-CE routing protocol for a VRF. ( this is the condition for the bug to trigger and is indicated by the log message you received)
And this can affect PIM adjacency across a VRF tunnel because of loss of MDT messages by BGP. ( this is the effect, doesnt not necessarly mean you have configured PIM, but if you do then you wont be able to form PIM adjacency across a VRF tunnel - Applicable only for MVPN)
HTH-Cheers,
Swaroop
For reference once again the Bug Case Details:
PIM neighbor not recognised with multicast vrf tunnel.
(Effect)
Symptoms: PIM neighbors do not recognize each other via a VRF tunnel
interface because multicast does not receive MDT updates from BGP. The output
of the show log command shows the following debug message:
%BGP-3-INVALID_MPLS: Invalid MPLS label (3) received in update for prefix
2:55:1111:192.168.31.1/32 from 192.168.31.1
(Trigger/Cause)
The PE-CE is using static routes or OSPF. There is no EBGP used between any of the PE-CE link. The bug's description doesn't really apply here.
or is there any other possible cause besides the bug ?
thanks
This bug is the closest to your symptom.
Since you have already identified it, the trigger condition would not be PIM as in your previous post, but EBGP between PE-CE.
Although if you do not have EBGP then I would suggest you should open a TAC case and they could probably update the case notes with this new behaviour.
The recommended tools to be used for any unexplicable error messages would be the
1) Error Message Decoder 2) Release Notes in the Caveats section.
HTH-Cheers,
Swaroop
Can you please attach a "show ver" from 172.18.255.2.
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
sh ver
IOS (tm) s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(18)SXF6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Mon 18-Sep-06 23:03 by tinhuang
Image text-base: 0x40101040, data-base: 0x42D90000
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(18)SXF6, RELEASE SOFTWARE (fc1)
uptime is 34 weeks, 6 days, 17 hours, 42 minutes
Time since switched to active is 34 weeks, 6 days, 17 hours, 31 minutes
System returned to ROM by Stateful Switchover (SP by power on)
System restarted at 00:40:31 MYT Fri Dec 1 2006
System image file is "disk0:s72033-advipservicesk9_wan-mz.122-18.SXF6.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco CISCO7609 (R7000) processor (revision 1.2) with 983008K/65536K bytes of memory.
Processor board ID FOX101504K9
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
Channelized E1, Version 1.0.
1 Enhanced FlexWAN controller (8 E1).
2 SIP-400 controllers (2 GigabitEthernet)(2 POS).
5 Virtual Ethernet/IEEE 802.3 interfaces
78 Gigabit Ethernet/IEEE 802.3 interfaces
3 Serial network interfaces
2 Packet over SONET network interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Could you please do a "show ip bgp vpnv4 vrf xxx labels" from 172.18.255.2, where xxx is the VRF for RD 65000:1.
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Attached the show output.
Send on behalf Boon Teong.
There are several scenarios, when a PE might send label 3, which is imp-null and thus should not be used with VPNv4 prefixes:
They are addressed in CSCsg55591.
An IOS upgrade might be required on the routers affected.
Hope this helps!
Regards, Martin
Martin,
I agree that the issue looks like CSCsg55591. The upgrade will not help at this point as this DDTS has not yet been integrated in 12.2(18)SXF or in 12.2(33)SRA and SRB.
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
we have a similar problem, but with MPLS label 0:
%BGP-3-INVALID_MPLS: Invalid MPLS label (0)
             received in update for prefix 58368:0:28056466:112.0.0.0/5 from 10.0.0.2
This message is seen on a Cisco 7206VXR NPE-G2 with IOS 12.4(24)T4. The box with the IP 10.0.0.2 is a Catalyst 3750 Metro with IOS 12.2(54)SE.
A "show ip bgp vpnv4 vrf xxx labels" (with xxx for the vrf) on the ME3750 shows the correct routes, there is no 112.0.0.0/5 seen (btw, the prefix 112.0.0.0/5 doesn't exist in the global routing table either).
Any ideas?
Thanks in advance
There are a few bugs related to invalid MPLS labels. We cannot distinguish them on the
value of the MPLS label, that does not much play a role.
Also, the router displaying the syslog message is the one that receives the invalid label,
i.e. the router checking the labels in the BGP updates. Nothing more.
The culprit is the router sending the BGP update with the invalid label, usually this
is the egress PE router.
In almost all cases the error message is harmless and does not cause packet drop.
So, best is to do nothing, unless users report issues.
Having said all of that, it looks like the prefix is corrupted. The RT-type is 58368, which is not valid. The rest
of the prefix is likely corrupted as well.
Then the issue you are seeing is CSCsk66240. Check the IOS version on the egress PE routers.
Still, this is likely an issue without any impact, as the prefix typically gets re-advertised shortly after
without any corruption or invalid label.
Luc
maybe it is helpful to solve
maybe it is helpful to solve the similar problem..
https://techzone.cisco.com/t5/Routing-Protocols/Invalid-MPLS-Label/ta-p/134674
3881
