CE Next-Hop-Self
Dear All,
I have this topology:
CE1-----CE2-----CE3
All routers are mpls vpn, and CE2 is router-reflector.
But CE1 can not see routes from CE3, becuase next-hop is invalid.
I have configured in CE2:
address-family ipv4 vrf A
neighbor VRFA peer-group
neighbor VRFA remote-as 65500
neighbor VRFA route-reflector-client
neighbor VRFA allowas-in
neighbor VRFA next-hop-self
neighbor 10.1.1.1 peer-group VRFA
neighbor 10.1.1.1 activate
neighbor 10.3.3.3 peer-group VRFA
neighbor 10.3.3.3 activate
no auto-summary
no synchronization
exit-address-family
but this config is not working.
I know that there is PBR config to set next-hop, but really do I need to use PBR?
Please, could you help me to solve this problem?
Thanks!
Cassio
1 ACCEPTED SOLUTION
Re: CE Next-Hop-Self
Cassio,
Sorry for the confusion. I see what you meant now. You are trying to apply next-hop-self on the RR.
next-hop-self will have no effect whatsoever on the routes reflected by the RR. It would only apply on eBGP learnt prefixes, in the RR had such connections of course.
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222 Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Cassio,
This is no different than with a regular (non-vrf) BGP environment. The next-hop is not changed by the RR and the RR clients have to have a route in the RIB to resolve the BGP next hop for the route to be considered valid by BGP.
People usually configure nexthop-self on the RR clients or redistribute the access link IP addresses into the IGP so that the BGP next hop resolution takes place properly.
Hope this helps,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Cuauhtémoc, Juárez
México
I'm a little confuse, but OK. I have configured loopback interface in IGP, of course that the problem was fixed, but the next-hop value was not changed, after this I have configured PBR to change next-hop, and it works fine.
Thank you very much
Cassio
Cassio,
I'm not sure I understand what the issue is.
- Why would need PBR?
- Do you mean that you configure a route-map to change the next hop on the RR?
- Why do you need to change the next-hop on the RR if you use next-hop self on CE1 and CE3?
- It is not recommended to change the NH on the RR.
Hope this helps,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Cuauhtémoc, Juárez
México
Cassio,
Hope this helps,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Cuauhtémoc, Juárez
México
Ohh, ok, I apologize for my English!
Cassio
Cassio,
You are welcome. No need to apologize for your english as it is quite good. It would have helped if I had read your posting thoroughly the first time around.
Cheers,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Cuauhtémoc, Juárez
México
180
