CEF load sharing question
7204VXR (NPE-G1) c7200-ik9s-mz.123-20.bin
I have 2 default routes and use CEF to load share - I've verified that the traffic is load sharing using Solarwinds.
Why are the packet counters all zero in the output of the show ip cef detail command ?
R01#show ip route 0.0.0.0
Routing entry for 0.0.0.0/0, supernet
Known via "static", distance 1, metric 0, candidate default path
Redistributing via eigrp 100
Advertised by eigrp 100 route-map redistribute_static
Routing Descriptor Blocks:
193.38.171.1
Route metric is 0, traffic share count is 1
* 193.38.171.2
R01#show ip cef detail
IP CEF with switching (Table Version 5216396), flags=0x0
1324 routes, 0 reresolve, 0 unresolved (0 old, 0 new), peak 7
23 instant recursive resolutions, 0 used background process
1324 leaves, 176 nodes, 363384 bytes, 3861253 inserts, 3859929 invalidations
5 load sharing elements, 1680 bytes, 5 references
universal per-destination load sharing algorithm, id 32CC272F
3(0) CEF resets, 1291566 revisions of existing leaves
Resolution Timer: Exponential (currently 1s, peak 1s)
1351539 in-place/0 aborted modifications
refcounts: 47788 leaf, 45312 node
Table epoch: 0 (1324 entries at this epoch)
Adjacency Table has 130 adjacencies
0.0.0.0/0, version 5216346, epoch 0, per-destination sharing
0 packets, 0 bytes
Flow: AS 0, mask 0
via 193.38.171.1, 0 dependencies, recursive
traffic share 1
next hop 193.38.171.1, GigabitEthernet0/2 via 193.38.171.1/32
valid adjacency
via 193.38.171.2, 0 dependencies, recursive
traffic share 1
next hop 193.38.171.2, GigabitEthernet0/2 via 193.38.171.2/32
valid adjacency
0 packets, 0 bytes switched through the prefix
tmstats: external 0 packets, 0 bytes
internal 0 packets, 0 bytes
0.0.0.0/32, version 1, epoch 0, receive
Flow: AS 0, mask 32
Re: CEF load sharing question
Darren,
Try enabling "ip cef accounting per-prefix" in global configuration mode.
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Thank you Mr Ritter - that fixed it.
156
