Cisco 7600 VPLS with ES40+ card.
Hi Freinds,
i'm trying to configure a VPLS back from ASR9K to 7600 routers, i read the configuration guide for 7600 ES40+ card for VPLS
but stil unable to get it to work, i'm posting this sample configuration part of the needed config:
ethernet evc VPLS
l2 vfi VPLS manual VPLS
vpn id 1000
neighbor 172.18.1.1 1000 encapsulation mpls
neighbor 172.18.1.2 1000 encapsulation mpls
interface GigabitEthernet4/1
service instance 100 ethernet
  encapsulation dot1q 100
  bridge-domain 100
vlan 100
interface vlan 100
xconnect vfi VPLS
i need to bring vlan 100 to part of ASR9K BD, from ASR9K full mesh is working fine.
any one to help me find the missing part of the configuraiton or provide sample steps for that.
thanks alot.
Mohamed.
Hi Mohamed
Maybe MTU need to be checked .. As you know MTU calculations in IOS is different than that of XR ; there is a difference of 14
Can you post ASR9k config
Sherif Ismail
Hi Sherif,
it's normal configuration without any mtu modification under sub-interface:
interface GigabitEthernet1/0/0/1.100 l2transport
rewrite ingress tag pop 1 symmetric
no shut
interface BVI100
ipv4 address 192.168.100.100 255.255.255.0
no shut
l2vpn
pw-class PW-Class-TAG
  encapsulation mpls
   transport-mode ethernet
bridge group DC-VLAN
  bridge-domain VLAN-100
   vfi VLAN-100
    neighbor 109.x.x.x  pw-id 100
   routed interface BVI100
Re: Cisco 7600 VPLS with ES40+ card.
Hi Mohamed
Is problem solved ?
From above I can see you are popping the tag "rewrite ingress tag pop 1 symmetric" at ASR9K but not at 7600.
Also not sure but wonder what the use of routed interface BVI100 configured at ASR9k since you are using VPLS
When i labbed a similar topology VCs were up but no data was passing
https://supportforums.cisco.com/message/4070576#4070576
Sherif Ismail
Hello Mohammed,
Please, gather the following output from 7600 box:
show mpls l2 vc 1000 detail
Thank you
Best regards,
Dmitry Skotnikov
-- Best regards, Dmitry Skotnikov
Is your ES card on the egress. Looks lime it is on the ingress. The ES card for VPLS must be core facing so that card can tag the BVI packet withe the pw tag.
Also looks like you don't have bridge-domain 100 created (or at least not from the config shown).
Hi All,
sorry for slow respond from my side and appreciate all your support.
all box's on the network has been replaced with ASR9K, thus no migration compatalibity issue now.
Sherif Ismail:  we are using a  routed interface BVI100 configured at ASR9k for Metro switches HSRP gateway,
the network is Ring, the BVI running with HSRP for Ring MGT only.
Mohamed.
979
