MPLS
Hello Everyone, I am new to segment routing. I am trying to learn the dynamic option of segment routing traffic engineering. I have 2 directly connected routers.R1---R2R1's Gi0/0/0/1 IP address 100.10.20.1R2'2 Gi0/0/0/1 IP address 100.10.20.21.1.1.1 ...
  I know well if we have several paths to the destination, we will BGP Best Path Selection . In which case we were obliged to use BGP Best Path Selection Algorithm?
Hi, I have configured SRTE policy on one NCS6K-1(head-end) to other NCS6K-2's(tail-end) loopback address. I have tried both the static policy and dynamic policy as well. Both are not working fine. Here are the quick SR-Configs and ISIS configs. Pleas...
darshan kn by Cisco Employee
  • 199 Views
  • 5 replies
I am studying for the CCNP Service Provider and I am trying to understand the Route Reflector design and configuration regarding MPLS LDP.  I have read that the Route Reflector does not need MPLS with LDP since is not part of the forwarding plane. Bu...
Hi guys, When i configure the option b BGP on my ASR 9006 i need to enable the labeled unicast in BGP to the neighbor to see the mpls interface enable in the router, this ASBR is PE/RR inline too. Then I eliminate the labeled-unicast but the mpls int...
Ignacho by Level 1
  • 372 Views
  • 5 replies
  • 1 Helpful votes
I've got a lab (in EVE-NG) with a number of different devices. Some are from Cisco, some aren't. I'm currently working through scenarios with mixed environment (vEOS 4.31, XRv9000 7.7.1, nxosv9k-10.3.1.f).In this portion of the lab scenario there is ...
ek1 by Level 1
  • 174 Views
  • 0 replies
My company is going to be migrating from on prem to an all SaaS world. We currently have a DC that will be going away in the next year and about a 1/4 of our locations will be moving off MPLS to DIA circuits with Meraki equipment. For the sites that ...
I have configured HSRP for High Availability but now from VPC I'm not able to reach vpc.Below is my routers and switch configuration. Thank youR1!!interface GigabitEthernet1ip dhcp client client-id ascii 9MGT16SBA3Jip address dhcpnegotiation autono m...
dissai by Level 1
  • 402 Views
  • 5 replies
Unanswered Topics
