Configuring a Pre-Shared Key on gateway device
Mr. VRuhil thank you for taht link that you sent me but unfortunately it did not help. ( the link for cisco vpn client v5.0)
What i really need is CISCO SECURE VPN CLIENT v1.0 or v1.1. Yes i know that its in the EOS/EOL now
Am using this configuration on my gateway device
Task 1—Configuring a Pre-Shared Key
And this configurations on the client side is what i wanted to do.
Task 2---Network Security policy:
1- Myconn
         My Identity = ip address
                 Connection security: Secure
                 Remote Party Identity and addressing
                         ID Type: IP subnet
                         10.21.1.0 (range of inside network)
                         Port all Protocol all
                 Connect using secure tunnel
                         ID Type: IP address
                         99.99.99.1
                         Pre-shared key = cisco1234
         Authentication (Phase 1)
         Proposal 1
                 Authentication method: pre-shared key
                 Encryp Alg: DES
                 Hash Alg: MD5
                 SA life: Unspecified
                 Key Group: DH 1
         Key exchange (Phase 2)
         Proposal 1
                 Encapsulation ESP
                 Encrypt Alg: DES
                 Hash Alg: MD5
                 Encap: tunnel
                 no AH
2- Other Connections
             Connection security: Non-secure
             Local Network Interface
                 IP Addr: Any
                 Port: All
With Xauth enabled on the router, when the user tries to connect to a device inside the router (here a ping -t #.#.#.# was performed), a gray screen appears:
User Authentication for 3660
Username:
Password:
408
