Configuring CE Router for eBGP
I'm configuring a CE router to connect to a PE router using eBGP as the PE-CE routing protocol. The site is a stub site. The LAN addresses are subnetted from the summary 10.1.0.0/16. The CE config as follows:
interface Serial0/0
description *** Connection to MPLS PE Router ***
ip address 1.1.1.2 255.255.255.252
interface Vlan10
description *** User Segment 1 ***
ip address 10.1.10.1 255.255.255.0
interface Vlan20
description *** User Segment 2 ***
ip address 10.1.20.1 255.255.255.0
interface Vlan30
description *** User Segment 3 ***
ip address 10.1.30.1 255.255.255.0
router bgp 64512
neighbor 1.1.1.1 description *** MPLS PE Router Peer ***
neighbor 1.1.1.1 remote-as 100
redistribute connected
no synchronization
no auto-summary
Alternatively, I'd configure as follows:
ip route 10.1.0.0 255.255.0.0 Null0
router bgp 64512
network 10.1.0.0 netmask 255.255.0.0
no synchronization
no auto-summary
Which of the above methods of configuration is more recommended as per best practices?
Please advise.
Thank you.
B.Rgds,
Lim TS
1 REPLY
Re: Configuring CE Router for eBGP
As a best practice , static advertisement of subnets with a network and matching route ( a null route with 254 metric ) would always be used .
But it depends on the scenarios
1.If you consider a ISP , he might have subnetted a /24 and given to many customers , so he would not have a matching /24 route , so he would advertise with static advertisments.
2.ISP might have multiple /24 routes in the routing table , but in case of any igp fluctuation would result in bgp routes getting advertised and retreived from internet and may result in bgp dampening , so a static advertisement would not disturb the bgp advertisements eventhough you have a igp fluctuation
In your case , you can go for any method ,
1.Advertisement of the subnet depends on your status of the vlan
2.Advertisment of route happens eventhough any one of your vlan is down and traffic would come and drop in your router .
Hope this helps
regards
vanesh k
115
