DHCP VRF Linkstar Viasat
I have some problems trying assing an IP via DHCP with VRF and Viasat system.
The problem is that the request for the NEW IP address come from the Vsat to the router via the managenemt IP, and I need to assing an IP address to a VRF configured into the router. I can not change the IP address for the management, and of course, I can not assign an IP address into the same segment for management address to a customer equipment.
Thank you for the response.
Brgds
The router is a Cisco 2851 with 12.4T.
The system is a Vsat Broadband Viasat.
1 REPLY
Re: DHCP VRF Linkstar Viasat
I am not able to get the sequence of request flow.
If I understand it right, do you assign VRF IP address via DHCP, and the DHCP server is the VSAT ?
If you can elaborate further with more details, that should be good.
HTH-Cheers,
Swaroop
286
