DSL Interfarface over ATM
The list below is an output of "show dsl interface ATM 0". Can soneone explain this output and what are the limits values.
ATU-R (DS) ATU-C (US)
Modem Status: Showtime (DMTDSL_SHOWTIME)
DSL Mode: ITU G.992.1 (G.DMT)
ITU STD NUM: 0x01 0x01
Vendor ID: 'ALCB' 'ANDV'
Vendor Specific: 0x0000 0x0000
Vendor Country: 0x00 0x00
Capacity Used: 40% 22%
Noise Margin: 22.0 dB 31.0 dB
Output Power: 20.0 dBm 10.5 dBm
Attenuation: 45.5 dB 28.5 dB
Defect Status: None None
Last Fail Code: Protocol error
Selftest Result: 0x00
Subfunction: 0x15
Interrupts: 647 (1 spurious)
Activations: 1
Init FW: embedded
Operartion FW: embedded
SW Version: 3.919
FW Version: 0x1A04
Interleave Fast Interleave Fast
Speed (kbps): 0 1856 0 128
Reed-Solomon EC: 0 0 0 0
CRC Errors: 0 14 0 96
Header Errors: 0 2 0 6
Bit Errors: 0 0
BER Valid sec: 0 0
BER Invalid sec: 0 0
LOM Monitoring : Disabled
DMT Bits Per Bin
00: 0 0 0 0 0 0 0 0 0 0 0 2 3 4 4 4
10: 4 4 4 4 4 3 3 3 2 2 2 0 0 0 0 0
20: 0 0 0 0 0 0 0 2 2 2 3 4 4 4 4 5
30: 5 5 5 5 5 5 5 6 6 6 6 6 4 6 6 6
40: 0 4 4 5 5 6 5 6 5 6 5 5 6 5 5 6
50: 6 6 6 6 6 6 6 6 5 5 5 5 6 5 5 5
60: 5 2 5 5 5 4 5 5 5 5 5 5 5 5 5 5
70: 3 4 4 4 4 5 5 4 2 4 4 2 4 4 4 4
80: 2 4 2 2 4 2 2 4 4 4 4 4 4 4 4 4
90: 4 3 3 2 2 0 2 2 0 2 2 2 2 2 2 2
A0: 2 2 2 0 2 2 2 2 0 2 0 2 2 2 2 2
B0: 2 2 0 0 0 2 2 2 2 0 0 0 0 0 0 0
C0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
D0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
E0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
F0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Training log buffer capability is not enabled yet.
TIA
Mario
1 REPLY
Bronze
Re: DSL Interfarface over ATM
The outputs basically display the layer-1 and layer-2 parameters for the DSL interface. See if this link helps you :
http://www.cisco.com/en/US/products/hw/routers/ps221/products_implementation_design_guide09186a00800faf11.html
150
