Community Member
Egress blocking / Speed Mismatch in MPLS
I connect multiple sites through a full mesh MPLS cloud. My main site has a 45Mbps DS3 connection into the cloud and the other sites have varying speeds 2-20 Mbps. How do I prevent the smaller sites from being overloaded with traffic by the main sites?
Re: Egress blocking / Speed Mismatch in MPLS
Dan,
The best way would be to do traffic shaping per remote site on the main (hub) site.
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Community Member
Hi hr, can you be a little more specific. Are you saying that I should (on a per site basis) create class maps for all traffic (obviously I can use class default) and then a policy map with explicit bandwidth statements that equals the total bandwidth of the remote site? I only have a single connection into the MPLS cloud so I can only apply one "service policy output" to that interface and with 30 sites I am not going to be able to specify enough bandwidth for each site.
Best regards,
Dan
Dan,
What I meant is that you need to identify the traffic destined to each spoke site, map it to a separate class-map and perform traffic shaping for each and every one of these class-maps (similar to per DLCI traffic shaping with FrameRelay). This is the only way you can guarantee that you will not overwhelm the remote site link.
policy-map MPLS_Sites
class Site_1
match access-group Sites1
shape average 1540000
class Site_2
match access-group Sites2
shape average 512000
class Site_n
match access-group Sitesn
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Community Member
Thanks hr, since I am also using LLQ would the following config be correct.
class-map match-all VIDEO
match dscp af31
class-map match-all VOICE
match dscp ef
class-map match-all SITE_1
match access-group name SITE-1-SUBNETS
class-map match-all SITE_2
match access-group name SITE-2-SUBNETS
class-map match-all SITE_3
match access-group name SITE-3-SUBNETS
policy-map SITE_LLQ
class VOICE
priority percent 20
class VIDEO
bandwidth percent 30
class class-default
fair-queue
random-detect
policy-map MPLS_SITES
class SITE_1
shape average 2000000
service-policy SITE_LLQ
class SITE_2
class SITE_3
shape average 15440000
class class-default
Dan
Hi Dan,
This would be the correct approach indeed.
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
599
