EIGRP and MPLS
Can you run EIGRP as a CE to PE protocol ? Is anybody doing this ? Are there any limitations/problems ?
Re: EIGRP and MPLS
Today EIGRP is not supported between CE-PE. As far as I know there is no limitation/problem. I think it may be supported in the future.
Mazhar Karagulle
CCIE# 6683 R&S-C&S
Re: EIGRP and MPLS
EIGRP between CE-PE will be available in the near future. I saw today this topic on the Feture Navigator.
Re: EIGRP and MPLS
Hi Hilary,
I think it is supported in 12.0(22)S
Check out this URL:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/relnote/
regards
javed
Re: EIGRP and MPLS
EIGRP between PE and CE is available in 12.0.22S.
Which gear you are using ?
Each gear has its own limitations in terms of vrf and vrf routes.
201
