EoMPLSoGRE on ASR 1002
I want to run EoMPLSoGRE between 2 data centers terminating the GRE and pwire on the ASR. Couple of questions: 1) Are there any special requirements on the ASR to support this? 2) Any caveats with running this in this manner?
My first hop is L3 with my provider and hence the need to run EoMPLSoGRE. Thanks for your help
1 ACCEPTED SOLUTION
Re: EoMPLSoGRE on ASR 1002
You need IOS XE 2.4.1 minimum to have this feature.
Laurent.
Laurent.
Laurent,
Thanks for the quick response.
375
