dfh
EXP bits with Label Stacking
In 12.0S, with ATOM or L3VPNs and label stacking which label's EXP bits are set using 'set mpls experimental' or using rate-limits? All labels in the stack?
I see the newer 'set mpls experimental' commands in 12.2 and 12.3 that can control which label's EXP bits are set; topmost, etc. However, I need 12.0S for any-to-any ATOM.
Thanks.
1 ACCEPTED SOLUTION
Re: EXP bits with Label Stacking
This command will set the EXP bits on all labels at label imposition. The IP Precedence bits will not be affected.
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
1 REPLY
Hope this helps,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
197
