Filtering methods inside a VRF in MPLS VPN
we have a network with MPLS VPN and several VRFs involved.
Inside a certain VRF I need to avoid that two particular networks can talk to each other.
Can you give me a hint of what can be a solution to implement this ?
Marco
1 REPLY
Re: Filtering methods inside a VRF in MPLS VPN
Hi Marco,
To prevent connectivity between two networks where a MPLS VPN is involved you can apply the same methods as in a "normal" router network. Just think of the complete MPLS VPN (PE to PE) as being one big "router simulator".
You could either implement ACLs on the interfaces connecting to the PE or filter routing updates between sites - depending on your topology. When filtering routing updates seems the way to go, you should also have a look into selective import or export. With the help of a route-map one can selectively insert single networks into a VPN by selectively attaching route-targets to BGP updates.
Regards, Martin
197
