Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
FRoMPLS between Cisco & Juniper
Hi!
I'm trying to set up a FRoMPLS connection between a Cisco and a Juniper router. The same config. works fine between Ciscos.
The mpls l2transport vc is not working.
Re: FRoMPLS between Cisco & Juniper
Why is the LDP session to the j4300 seen as 10.15.10.231 if the loopback address is 10.15.10.246 In the configuration.
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Hi!
You are right; we had the wrong loopbak address. It's fixed now, but it still doesn't work. We changed a couple of things. This is the latest test. See attached file.
Is the control-word right?
The CW is find. The Martini draft specifies that the CW is required but that its use is optional. It the case it is not used it has to be set to 0, which is the case here.
So what doesn't work now. You can't pass traffic from one CE to the other?
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Do you see the PVCs as up on both CEs?
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
173
