FRoMPLS QoS
In the service provider network with FRoMPLS.
topology is CE1-PE1-CORE-PE2-CE2.
customer network is Frame relay network.
SP policy is when ingress traffic coming to PE1 with DE bit then setting up EXP bit 1 and also exceed packet setting up EXP bit 1.
If, PE2 output interface is becomimg congetion status, then SP want to drop packet with EXP bit 1or DE bit.
Now, I use CB policing at PE1and PE2. but, this is not support queueing control.
I want solving this problem to use DE bit or EXP bit .
What solution is this policy?
2 ACCEPTED SOLUTIONS
Purple
Re: FRoMPLS QoS
Here's one possible solution - assuming that anything tagged with Exp1 is more likely to be dropped then anything else that is not...
class-map NonExp1
match mpls experimental topmost 0 2 3 4 5 6 7
policy-map Output
class NonExp1
bandwidth
class class-default
fair-queue
With the above policy, all traffic marked EXP 1 will fall through to class-default. Since you have not give class-default a bandwidth reservation, it will only get service if the NonExp1 class is not using up all the bandwidth. Therefore, in times of congestion, your class-default traffic (i.e. EXP 1 traffic) will get dropped and everything else will go through.
Hope that helps - pls rate the post if it does.
Paresh
Re: FRoMPLS QoS
you could match on the DE bit outgoing. Or you match on Exp bits on incoming interface to the PE and set a qos-group for the specific traffic. Something like
ip cef
class-map match-all Exp1
match mpls experimental 1
policy-map PEin
class Exp1
set qos-group 1
class-map match-all QoSgr1
match qos-group 1
policy-map CustOUT
class QoSgr1
bandwidth 128
NB.: I did not implement FRoMPLS in a production environment, so it might not work with your network.
Hope this helps! Please rate all posts.
Regards, Martin
Purple
Re: FRoMPLS QoS
class-map NonExp1
policy-map Output
class NonExp1
bandwidth
class class-default
fair-queue
Paresh
Re: FRoMPLS QoS
thanks for your help.
but, label is already poped on outgoing interface.
which is to change just frame relay frame.
Is it not correct?
and then, I want to change exp 1 to de bit with priority change
Re: FRoMPLS QoS
ip cef
policy-map PEin
class Exp1
set qos-group 1
match qos-group 1
policy-map CustOUT
class QoSgr1
bandwidth 128
Regards, Martin
Re: FRoMPLS QoS
thank you for your advice.
I solved this problem.
example is bellow.
policy-map PEin
class Exp1
set qos-group 1
match not qos-group 1
policy-map CustOUT
class QoSgr1
bandwidth 128
class class-default
fair-queue
set fr-de
170
