Community Member
Global transport inside VRF
I would like to setup a router like the following
int fa0
ip vrf forwarding inet
ip addr x.x.x.x
int t0
ip addr y.y.y.y
ip route 0.0.0.0 0.0.0.0 vrf inet
Has anyone done this?
I know that the reverse works ok (you can transport VRFs in a GRE tunnel (VRF inside the tunnel, global IP routing outside on the GRE-layer).
Any help appreciated, thanks.
Re: Global transport inside VRF
If i get your question right, this link should to of some help.
http://www.cisco.com/en/US/tech/tk436/tk832/technologies_configuration_example09186a0080231a3e.shtml
HTH-Cheers,
Swaroop
Community Member
That's close, it doesn't address GRE/DMVPN interfaces, which don't follow the same rules.
In other words, a global GRE interface that uses a VRF interface as the 'tunnel source' interface.
195
