How many pseudowires supports an 7600 and an 12000
Hi folks
Could sombody tell me how many pseudowires supports the following platforms:
7600
12000
Does it depend the type of pseudowire used?
thanks,
Silver
Re: How many pseudowires supports an 7600 and an 12000
You can configure pseudowire redundancy by configuring two pseudowires for an ATM or CEM interface: a primary pseudowire and a backup (standby) pseudowire. If the primary pseudowire goes down, the router uses the backup pseudowire in its place. When the primary pseudowire comes back up, the backup pseudowire is brought down and the router resumes using the primary.
For the further assistance following URL may help you
http://www.cisco.com/en/US/docs/interfaces_modules/shared_port_adapters/configuration/7600series/76cfgcep.html#wp1764210
Thanks Didya.
As aditional information do you know what is the limit of pseudowires you can configure in an 12000 and an 7600 router? I am going to use these machines as PE routers and I am going to mix L3 VPNS with L2 Pseudowires.
Hall of Fame Super Silver
Hello Pedro,
both for L3 MPLS VPN and xconnect you need at least one access link, a Vlan subif typically or a whole port.
So the PE / L2 PE is limited by IDB table size limit that depends on supervisor and IOS image.
For both images you should be able to build 4000
see for IDB limits
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_tech_note09186a0080094322.shtml
but VRF limit is 1024 on C7600
MPLS in hardware to enable use of Layer 3 VPNs and EoMPLS tunneling; up to 1024 Virtual Route Forwarding (VRF) routes with a total of up to 256,000 routes per system
see
http://www.cisco.com/en/US/prod/collateral/routers/ps368/product_data_sheet0900aecd8057f3b6.html
12000 should scale more in terms of VRFs
Hope to help
Giuseppe
359
