ip nat enable + default route for VRF
I have a test vrf setup, and am attempting to provide Internet access into it.
Ref: http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123newft/123t/123t_14/gtnatvi.htm
I've enabled nat on Interface that has Internet Connectivity:
interface FastEthernet0/0.22
description NAT INT for VRF TEST
encapsulation dot1Q 22
ip vrf forwarding TEST10
ip address 203.149.77.38 255.255.255.252
ip nat enable
no snmp trap link-status
Created NAT pool
ip nat pool NAT 203.149.77.45 203.149.77.46 netmask 255.255.255.252 add-route
ip nat source list 1 pool NAT vrf TEST10 overload
ACLs for CE's within vrf TEST10
access-list 1 permit 10.0.0.0 log
access-list 1 permit 192.168.1.0 0.0.0.255 log
And then tried to add default route for vrf TEST10 of interface FastEthernet0/0.22, but am denied:
#ip route vrf TEST10 0.0.0.0 0.0.0.0 fastEthernet 0/0.22
% For VPN routes, must specify a next hop IP address if not a point-to-point interface
I've tried adding the other side of the nat interfaces /30 (203.149.77.37) - but CE's attached to vrf TEST10 cannot get to the Internet?
Any suggestions are greatly appreciated.
MB
Purple
Re: ip nat enable + default route for VRF
I would try something like this:
! you need to create the VRF on the NAT-PE router
ip vrf TEST10
rd ...
route-target import ....
route-target export ....
ip route 203.149.77.45 255.255.255.252 null0
ip route vrf TEST10 0.0.0.0 0.0.0.0 fast0/0.22 203.149.77.37 global
interface fast0/0.22
! since this interface belongs to the global routing table, do not place it in a VRF
ip nat outside
router bgp
address-family ipv4 vrf TEST10
redistribute static
default-information originate
! do the following on each of your links to other Ps and PEs
interface
ip nat inside
ip nat inside source list 1 pool NAT vrf TEST10 overload
Hope that helps - pls rate the post if it does.
Paresh
Thanks for the response - Any reason not to use "ip nat enable"?
This PE has two FE feeds - One that connects to the rest of the network and runs mpls(So reluctant to enable nat on this interface), the other runs dot1q, and was to be used exclusively for Internet Access for VRF's (Each vrf being assigned there own dot1q Int to allow for easier accounting of Internet traffic used) - Hence the reason I wanted to just use "ip nat enable" on the dot1q Ints, and then assign them to vrfs for Internet Access.
Is the above do-able?
Purple
I just prefer to use 'ip nat [inside|outside]' - old habits dies hard ! But I believe that you could use either.
What you are after is certainly do-able. Take my config and instead of configuring 'ip nat inside' on the MPLS interfaces, configure it on the dot1q interfaces...
Paresh
Thanks - So I'm guessing I would need to enable "ip nat outside" on the other side(i.e. Another Router) of the dot1q /30? Pretty sure the IOS on that router doesn't support nat(Service Provider).
Purple
Not really. You would configure 'ip nat outside' on the interface to the Internet on the same router (in my config, I had it on fast0/0.22)
Paresh
Ok - This is what I currently have:
description NAT INT for VRF TEST to ERT02-BNE
ip nat outside <-- Also tried "ip nat inside"
ip route 203.149.77.44 255.255.255.252 Null0
ip route vrf TEST10 0.0.0.0 0.0.0.0 FastEthernet0/0.22 203.149.77.37 global
Attempting to get(trace/ping) to any address not within the vrf TEST10 (From device in vrf TEST10) results in timeout at 203.149.77.38 router.
Trace'ing with a source IP of 203.149.77.38 to an Internet address is successful
#sh ip route vrf TEST10
Routing Table: TEST10
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 203.149.77.37 to network 0.0.0.0
10.0.0.0/8 is variably subnetted, 6 subnets, 2 masks
C 10.0.0.2/32 is directly connected, Virtual-Access7
B 10.0.3.0/24 [200/0] via 203.149.76.248, 3w0d
C 10.0.0.0/24 is directly connected, Loopback10
B 10.0.6.0/24 [200/0] via 203.149.76.250, 1w5d
B 10.0.7.0/24 [200/0] via 203.149.76.247, 1w4d
B 10.0.5.0/24 [200/0] via 203.149.76.249, 3w6d
U 192.168.1.0/24 [1/0] via 10.0.0.2
S* 0.0.0.0/0 [1/0] via 203.149.77.37, FastEthernet0/0.22
Purple
John,
Which of your interface goes to the Internet ?
Paresh
interface FastEthernet0/0.22 has Internet Access.
Purple
Then that interface should be configured as the outside NAT interface.
Another Q: which interface belongs to the TEST10 VRF ? That interface should be configured as the inside NAT interface.
Paresh
Ahh - There's my problem - TEST10 vrf are all DSL services(L2TP vpdn's) being placed into vrf TEST10 via Radius reply attribute...so they are all virtual-access ints dynamically created once the authenticate.
Purple
Ok.. so make sure that you have 'ip nat inside' configured on the virtual-template and this should work.
Paresh
Thanks for the assistance thus far Paresh - Greatly apperciated....I had already tried that...unfortunately still no joy:
ip nat outside
no ip virtual-reassembly
interface Virtual-Template1
description L2TP-1 Termination
ip unnumbered Loopback1
ip nat inside
qos pre-classify
ppp authentication chap callin
Rebooted the test DSL router, but it still cannot get beyond the vrf.
If I do a:
#sh ip nat translations vrf TEST10
or
Should I be seeing something? At the moment there is nothing.
Purple
What source address are you pinging from ?
Paresh
Directly from ADSL router that is assinged 10.0.0.2 (WAN). I have also tried pinging with source IP of 192.168.1.1 (ADSL Router LAN IP)
Purple
Well, it's gotta nbe source from a 192.168.1.x address because of your ACL 1.
IS there any chance you being able to run a debug on that router - something like 'debug ip nat vrf' to see what is breaking ?
Paresh
acl 1 also has 10.0.0.0:
#show access-lists 1
Standard IP access list 1
10 permit 10.0.0.0 log
20 permit 192.168.1.0, wildcard bits 0.0.0.255 log
I have the following debugging enabled, yet I see nothing in the logs when trying to get out from DSL Router:
# sh debugging
Generic IP:
IP NAT detailed debugging is on for access list 1
IP NAT VRF debugging is on
IP NAT NVI debugging is on
Silver
Do you have routes for the 10.0.0.0 and 192.168.1.0 addresses that you are natting from in the global routing table? It is my guess that the packets are being translated but they can not move from the global routing table back to the vrf.
You might need to configure a global route for those addresses pointing to the vrf interface.
Hope this helps
Purple
Could you post the output of 'sh ip ro vrf TEST10' ?
By the way, to match 10.0.0.0/24, you need the following ACL line:
access-list 1 permit 10.0.0.0 0.0.0.255 log
Paresh
I have had to unfortunately put this on hold and run with a Pix for supplying Internet into vrf's....got clients that require this service asap :)
Found the following bug which may/may not relate...but it looks like it might:
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCsb80566&cco_product=IOS&fset=&swver=12.4&keyw=nat&target=4&train=T
I'm currently running 12.4(4)T
Thanks again for your help.
876
