Is auto-bw recommended in MPLS TE environment?
Hi Sir,
Is automatic bandwidth adjustment recommended in MPLS TE environment? The configuration of a primary TE tunnel is as follows:
interface Tunnel1
load-interval 30
tunnel mpls traffic-eng auto-bw
Thank you.
B.Rgds,
Lim TS
1 REPLY
Re: Is auto-bw recommended in MPLS TE environment?
It depends on your requirement. And how important is the primary path BW for you.
As the traffic already using the backup path as primary may be depleted of BW.
Since these are all knobs or features, there is nothing like only this or that is recommended. you will need to study and baseine your BW requirements and then go ahead with unlimited, auto or fixed.
HTH-Cheers,
Swaroop
138
