IS IPSEC FEATURE REQUIRED IN THE CUSTOMER EDGE ROUTER ?
Hi folks,
In the context of the IPVPN (MPLS), is the customer edge router has to
support IPSEC?
ConceptZone
Re: IS IPSEC FEATURE REQUIRED IN THE CUSTOMER EDGE ROUTER ?
Let me more specific
I have 1750 router equipped with 8F/32D.
Do I need to establish IPSEC with the Telco?
In this case I have to upgrade the router to at leased 16F/48D
Advice me please
Thanks Again
Silver
Nopes it would nt be needed at all. But yes if you are looking for Security along the last mile, you can look at IPSec. But if you are looking for security across the SP core, you wouldnt need IPSec with ur Telco.
Thanks Allot :)
But most of the bankings always require additional security for their last mile connections. And IPSec is always their choice, but they need to upgrade all CEs in order to run IPSec.
jasrine47
http://ciscorouterconfig.blogspot.com/
127
