ISIS Adj not coming up
I changed the MTU of my gige link from 1500 to 1600, and configured mpls MTU 1538. doing that ISIS does not form adj.
I see CLNS is showing neigbor but as ES-IS? why is that.
Router A:
interface GigabitEthernet0/0/9
description link to RouterB
mtu 1600
ip address x.x.x.x y.y.y.y
no ip directed-broadcast
ip router isis
no negotiation auto
tag-switching mtu 1538
tag-switching ip
isis network point-to-point
isis authentication mode md5
isis authentication key-chain KEY-ISIS
end
Router A neigbor:
RouterA#sh clns neighbors
System Id Interface SNPA State HT Type Protocol
RouterB(P-TGi0/0/9 001a.e3a2.8808 Up 292 IS ES-IS
Other end:
Router B:
interface GigabitEthernet0/0/8
description Connected to Router A
Gig0/0/9
mtu 1600
ip router isis
no negotiation auto
tag-switching ip
end
RouterA(P-EGi0/0/8 001b.2b04.ec09 Up 250 IS ES-IS
I cannot see ISIS neigbor here.
Re: ISIS Adj not coming up
Atif,
The IS-IS hellos are probably not getting across the link. The reason you are seeing the adjacency as ES-IS is that the ES-IS hellos are not padded, while the IS-IS hellos are.
Do you have a switch between the two routers? If so, make sure that the switch allows 1600 bytes packets through.
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
ok I see. I will try to find out. as it is WAN link provided by other provider.
thanks.
Another doubt I have is if after applying the mtu changes you shut/no shut both interfaces or just one.
Antonio
We did that, but did not work.
I will find out tomorrow what do we have in the middle...
If it is DWDM, will it affect us? is there MTU setting on it? I am not sure
On both sides issue a "show ip interface check the IP MTU value on each side.
Set the ISIS MTU on each respective interface to the IP MTU you observe and the adjacency will come up.
HTH-Cheers,
Swaroop
I agree with swaroop, this is due to the default hello padding, try disabling hello packet, if you are sure the both end point's MTU, this will reduce the CPU/BW. go into each interface and type
no isis hello padding
i did disable the padding, still does not come up.
only comes up when we reduce MTU to 1500. in the middle there is DWDM, which has enough limit for MTU
Atif,
It would definitely be worth pinging from one router to the other using packet sizes over 1500 bytes just to confirm your providers setting.
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
GigabitEthernet0/0/9 is up, line protocol is up
Internet address is x.x.x.x/30
Broadcast address is 255.255.255.255
Address determined by non-volatile memory
MTU is 1600 bytes
Helper address is not set
Directed broadcast forwarding is disabled
Multicast reserved groups joined: 224.0.0.2
Outgoing access list is not set
Inbound access list is not set
Proxy ARP is enabled
Security level is default
Split horizon is enabled
ICMP redirects are always sent
ICMP unreachables are always sent
ICMP mask replies are never sent
IP fast switching is disabled
IP fast switching on the same interface is disabled
IP Flow switching is disabled
IP CEF switching is enabled
IP Null turbo vector
IP multicast fast switching is enabled
IP multicast distributed fast switching is disabled
IP route-cache flags are Fast, Distributed, CEF
Router Discovery is disabled
IP output packet accounting is disabled
IP access violation accounting is disabled
TCP/IP header compression is disabled
RTP/IP header compression is disabled
Probe proxy name replies are disabled
Policy routing is disabled
Network address translation is disabled
WCCP Redirect outbound is disabled
WCCP Redirect inbound is disabled
WCCP Redirect exclude is disabled
BGP Policy Mapping is disabled
Interface config:
mtu 1600
ip address x.x.x.x 255.255.255.252
ip router isis NRP
no negotiation auto
tag-switching ip
end
this is the same config on the other side.
also if we have everything label switched is it necessary to set ip mtu?
hello
alternatively, you can decrease 'clns mtu' on your interface. But as you will apparently run MPLS on the link, it's worth checking the link 'real mtu'
regards
Etienne
Your config looks fine, can you run debug isis adj-pac and attach the o/p. this shouldprovide a clue whats going wrong.
HTH-Cheers,
Swaroop
To add more, my initial reply was based on similar experience, but between 76k and GSR-IOS XR. But did a quick test with 76k and dont see any problem neither am able to introduce such problem with similar config.
HTH-Cheers,
Swaroop
Here is the debug from one side:
gigi 0/0/9 is the one that does not come up:
Also interestingly I can ping (DF Set)across with Higher MTU:
GSR-A#ping
Protocol [ip]:
Target IP address: x.x.x.69 --> GSR B connected interface IP
Repeat count [5]:
Datagram size [100]: 1550
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface:
Type of service [0]:
Set DF bit in IP header? [no]: y
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 1550-byte ICMP Echos to x.x.x.69, timeout is 2 seconds:
GSR-B#ping
Protocol [ip]:
Target IP address: x.x.x.70
Repeat count [5]:
Sending 5, 1550-byte ICMP Echos to x.x.x.70, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/5/8 ms
This gige is connected via DWDM, and MTu is set 9600.
What else we can check for.
The debug from the other side would give a clue, as this guy seems to be on the lower end of the mtu, as you can see only outbound "sends" no receives.
It seems this side interface falls marked to the remote side mtu.
HTH-Cheers,
Swaroop
Here is the log from other side:
G0/0/8 on this side also does not recieve anything. In the middle there is DWDM and MTU is set to 9600, not sure what other reasons can be, setting MTU back to 1500 brings ISIS UP.
Oct 13 02:55:21.723 EST: ISIS-Adj: Rec serial IIH from *HDLC* (POS2/1/0), cir type L2, cir id 03, length 4469
Oct 13 02:55:21.723 EST: ISIS-Adj: rcvd state UP, old state UP, new state UP
Oct 13 02:55:21.723 EST: ISIS-Adj: Action = ACCEPT
Oct 13 02:55:23.099 EST: ISIS-Adj: Rec serial IIH from 0018.741e.5080 (GigabitEthernet0/0/0), cir type L2, cir id 00, length 1596
Oct 13 02:55:23.099 EST: ISIS-Adj: rcvd state UP, old state UP, new state UP
Oct 13 02:55:23.099 EST: ISIS-Adj: Action = ACCEPT
Oct 13 02:55:23.927 EST: ISIS-Adj: Sending serial IIH on POS2/1/0, length 4469
Oct 13 02:55:23.947 EST: ISIS-Adj: Sending serial IIH on POS3/1/0, length 4469
Oct 13 02:55:24.051 EST: ISIS-Adj: Rec serial IIH from 001b.2b8b.e41b (GigabitEthernet0/0/9), cir type L2, cir id 00, length 1496
Oct 13 02:55:24.051 EST: ISIS-Adj: rcvd state UP, old state UP, new state UP
Oct 13 02:55:24.051 EST: ISIS-Adj: Action = ACCEPT
Oct 13 02:55:24.223 EST: ISIS-Adj: Rec serial IIH from *HDLC* (POS3/0/0), cir type L2, cir id 02, length 4469
Oct 13 02:55:24.227 EST: ISIS-Adj: rcvd state UP, old state UP, new state UP
Oct 13 02:55:24.227 EST: ISIS-Adj: Action = ACCEPT
Oct 13 02:55:24.531 EST: ISIS-Adj: Rec serial IIH from *HDLC* (POS2/0/0), cir type L2, cir id 03, length 4469
Oct 13 02:55:24.531 EST: ISIS-Adj: rcvd state UP, old state UP, new state UP
Oct 13 02:55:24.531 EST: ISIS-Adj: Action = ACCEPT
Oct 13 02:55:25.568 EST: ISIS-Adj: Sending L2 IIH on GigabitEthernet0/0/8, length 1597
Oct 13 02:55:25.784 EST: ISIS-Adj: Sending serial IIH on POS2/0/0, length 4469
Oct 13 02:55:26.108 EST: ISIS-Adj: Sending serial IIH on GigabitEthernet0/0/9, length 1496
Oct 13 02:55:26.488 EST: ISIS-Adj: Sending serial IIH on GigabitEthernet1/0/0, length 1596
Oct 13 02:55:27.488 EST: ISIS-Adj: Sending serial IIH on POS3/0/0, length 4469
Oct 13 02:55:27.792 EST: ISIS-Adj: Rec serial IIH from 0018.741e.5080 (GigabitEthernet1/0/0), cir type L2, cir id 01, length 1596
Oct 13 02:55:27.792 EST: ISIS-Adj: rcvd state UP, old state UP, new state UP
Oct 13 02:55:27.792 EST: ISIS-Adj: Action = ACCEPT
Oct 13 02:55:28.292 EST: ISIS-Adj: Sending serial IIH on GigabitEthernet0/0/0, length 1596
Oct 13 02:55:29.080 EST: ISIS-Adj: Rec serial IIH from *HDLC* (POS3/1/0), cir type L2, cir id 01, length 4469
Oct 13 02:55:29.080 EST: ISIS-Adj: rcvd state UP, old state UP, new state UP
Oct 13 02:55:29.080 EST: ISIS-Adj: Action = ACCEPT
Oct 13 02:55:30.552 EST: ISIS-Adj: Rec serial IIH from *HDLC* (POS2/1/0), cir type L2, cir id 03, length 4469
Oct 13 02:55:30.552 EST: ISIS-Adj: rcvd state UP, old state UP, new state UP
Oct 13 02:55:30.552 EST: ISIS-Adj: Action = ACCEPT
Oct 13 02:55:30.648 EST: ISIS-Adj: Rec serial IIH from 0018.741e.5080 (GigabitEthernet0/0/0), cir type L2, cir id 00, length 1596
Oct 13 02:55:30.648 EST: ISIS-Adj: rcvd state UP, old state UP, new state UP
Oct 13 02:55:30.648 EST: ISIS-Adj: Action = ACCEPT
Oct 13 02:55:32.037 EST: ISIS-Adj: Sending serial IIH on POS2/1/0, length 4469
Oct 13 02:55:32.053 EST: ISIS-Adj: Rec serial IIH from *HDLC* (POS3/0/0), cir type L2, cir id 02, length 4469
Oct 13 02:55:32.053 EST: ISIS-Adj: rcvd state UP, old state UP, new state UP
Oct 13 02:55:32.053 EST: ISIS-Adj: Action = ACCEPT
Oct 13 02:55:32.329 EST: ISIS-Adj: Sending serial IIH on POS3/1/0, length 4469
Oct 13 02:55:33.173 EST: ISIS-Adj: Rec serial IIH from 001b.2b8b.e41b (GigabitEthernet0/0/9), cir type L2, cir id 00, length 1496
Oct 13 02:55:33.173 EST: ISIS-Adj: rcvd state UP, old state UP, new state UP
Oct 13 02:55:33.173 EST: ISIS-Adj: Action = ACCEPT
Oct 13 02:55:33.441 EST: ISIS-Adj: Sending L2 IIH on GigabitEthernet0/0/8, length 1597
Oct 13 02:55:33.529 EST: ISIS-Adj: Rec serial
Atif,
Ultimately, you need to verify that the physical network does support 1600 bytes. The best way to do that is by using an extended ping as follow:
R1#ping ip
Target IP address: 172.16.12.2
Repeat count [5]: 1
Set DF bit in IP header? [no]: yes
Sweep range of sizes [n]: y
Sweep min size [36]: 1498
Sweep max size [18024]: 1600
Sweep interval [1]:
Sending 103, [1498..1600]-byte ICMP Echos to 172.16.12.2, timeout is 2 seconds:
Success rate is 2 percent (3/103), round-trip min/avg/max = 20/36/60 ms
R1#
You see in this case that the MTU is 1500 bytes. The first 3 pings works (1498, 1499, 1500) and the rest of the ping fails.
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
ok. there were some layer2 tests done on the circuit and it could pass from 64 bytes to 2000 bytes with nor prpblems.
Tried pings with DF bit set for 1600 bytes p2p link IP and it is also fine.
I can try this as well. and will post the results.
Try 'no isis hello padding' on both sides. If adjacency comes up, then it's an MTU issue, otherwise it's something else. Debug from the other side would be indeed helpful.
"no isis hello padding" only applies after the session has been established. Hellos sent before session establishment are padded regardless.
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Here is another secnario in the LAB.
P1(GSR) --- P3 (GSR)
P1#sh cdp neighbors
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater
Device ID Local Intrfce Holdtme Capability Platform Port ID
P3 POS0/0/0 122 R 12410/PRP POS0/0/0
P1#sh clns neighbors
PE1 Gi1/1/0 0019.a98c.1440 Up 23 L2 IS-IS
PE1 Gi1/1/1 0019.a98c.1440 Up 26 L2 IS-IS
P3 PO0/0/0 *HDLC* Up 275 IS ES-IS
P1#
P1#sh run interface pos0/0/0
Building configuration...
Current configuration : 329 bytes
interface POS0/0/0
description Connected to P3 - POS 0/0/0
ip address 18.18.18.1 255.255.255.252
ip router isis
load-interval 30
tag-switching ip
crc 32
isis authentication key-chain ISIS
end
P1#sh ip int pos0/0/0
POS0/0/0 is up, line protocol is up
Internet address is 18.18.18.1/30
MTU is 4470 bytes
P1 sees other neigbors but not P3:
P1#sh isis neighbors
System Id Type Interface IP Address State Holdtime Circuit Id
PE1 L2 Gi1/1/0 18.18.19.1 UP 22 01
PE1 L2 Gi1/1/1 18.18.19.49 UP 28 02
P3#sh run interface pos0/0/0
Current configuration : 382 bytes
interface POS0/0/0
description Connected to P1 - POS 0/0/0
ip address 18.18.18.2 255.255.255.252
ip router isis
load-interval 30
mpls traffic-eng tunnels
tag-switching ip
crc 32
P3#sh clns neighbors
PE2 Gi1/1/0 0019.a98c.1400 Up 28 L2 IS-IS
PE3 Gi1/1/1 0019.a98c.1500 Up 29 L2 IS-IS
P1 PO0/0/0 *HDLC* Init 29 L2 IS-IS
P3#sh isis neighbors
PE2 L2 Gi1/1/0 18.18.19.17 UP 25 01
PE3 L2 Gi1/1/1 18.18.19.38 UP 27 02
P1 L2 PO0/0/0 18.18.18.1 INIT 28 00
P3#sh ip int pos0/0/0
Internet address is 18.18.18.2/30
MTU is 4470 bytes
Above session is stuck in INIT as MTU is 4470, it was working before but changing the redudnacy mode to SSO, cause reload and it is down.
Changin MTU to 1500, it is working:
P1(config)#int pos0/0/0
P1(config-if)#mtu 1500
P1(config-if)#^Z
P1#sh
*Nov 5 19:41:56.638 EST: %SYS-5-CONFIG_I: Configured from console by console
P1#sh isis ne
PE1 L2 Gi1/1/0 18.18.19.1 UP 26 01
PE1 L2 Gi1/1/1 18.18.19.49 UP 22 02
P3 L2 PO0/0/0 18.18.18.2 UP 23 00
P1#
other side:
P3(config)#int pos0/0/0
P3(config-if)#mtu 1500
P3(config-if)#^Z
P3#
*Nov 5 11:44:40.103 EST: %SYS-5-CONFIG_I: Configured from console by cisco on vty0sh isis ne
P3#sh i
P3#sh isis
P3#sh isis ne
PE2 L2 Gi1/1/0 18.18.19.17 UP 29 01
PE3 L2 Gi1/1/1 18.18.19.38 UP 23 02
P1 L2 PO0/0/0 18.18.18.1 UP 28 00
NOW if I change the MTU to 4470 it is ok, until i reset the interface.
not sure what is happening here.
increasing to 4470:
P3(config-if)#mtu 4470
P3(config-if)#^Z
P3#sh ip int
*Nov 5 11:46:30.491 EST: %SYS-5-CONFIG_I: Configured from console by cisco on vty0pos0/0/0
MTU is 4470 bytes
PE2 L2 Gi1/1/0 18.18.19.17 UP 26 01
PE3 L2 Gi1/1/1 18.18.19.38 UP 24 02
P1 L2 PO0/0/0 18.18.18.1 UP 25 00
P1 has session up too:
MTU is 4470 bytes
PE1 L2 Gi1/1/0 18.18.19.1 UP 24 01
PE1 L2 Gi1/1/1 18.18.19.49 UP 26 02
P3 L2 PO0/0/0 18.18.18.2 UP 21 00
now I shut the interface and no shut again same MTU problem. until i reduce it to 1500 and it comes up then i can make it 4470, only until the next interface reset.
P1(config-if)#sh
*Nov 5 19:47:34.029 EST: %LINEPROTO-5-UPDOWN: Line protocol on Interface POS0/0/0, changed state to down
P1(config-if)#no sh
P1(config-if)#
*Nov 5 19:48:13.596 EST: %LINK-3-UPDOWN: Interface POS0/0/0, changed state to up
PE2 L2 Gi1/1/0 18.18.19.17 UP 22 01
P1 L2 PO0/0/0 18.18.18.1 INIT 22 00
again INIT state.
Version 12.0(32)SY3
Summary of the problem:
- The problem occurs on ISIS Adj between GSR only.
- POS Links default MTU 4470.
- ISIS Adj Comes up initially; any resetting of neigbour router an interface or line card, line card reload, router reload, ADJ goes down.
- It only comes up when we reduce the MTU on links to 1500.
- After that increasing the MTU back to 4470 works fine until there is another neigbor router interface reset, and ISIS Adj goes down again.
- IOS version on GSR is: 12.0(32)SY3
Solution for POS interfaces.
Setting MTU lower than the default value fixes the problem.
We set it to 4460 on both sides and it works even after interface reset.
Gige point-to-point does not support more than 4200 when it is connected back to back.
Atif,
Also you might want to verify your ISIS mtu debug what is being sent out. You are going to have to make sure that the ISIS and Tagging mtu are the same accross both devices.
Cheers,
Lamar
Can you verify that the configs is ok?
Router A:
mtu 1600
ip router isis
no negotiation auto
tag-switching ip
end
Router A neigbor:
Other end:
Router B:
Gig0/0/9
mtu 1600
ip router isis
no negotiation auto
tag-switching ip
end
Atif,
I had the same problem, the only difference is that i am running a CSR1000V , i was trying with many commands to disable hello padding and i tried:
Under interface config
no isis hello padding always
Not even needed to shut/no shut the interface. It worked for me, let me know if it does for you.
BR
Yun
4796
