LDP over OSPF- tunnel not coming up
Here are the two configs.
The OSPF neighbor relationship shows up. A show interfaces serial1/0/0 detail shows:
bottom-7507#show mpls interfaces s1/1/0 det
Interface Serial1/1/0:
IP labeling enabled (ldp):
Interface config
IGP config
LSP Tunnel labeling not enabled
BGP labeling not enabled
MPLS operational
Optimum Switching Vectors:
IP to MPLS Turbo Vector
MPLS Turbo Vector
Fast Switching Vectors:
IP to MPLS Fast Switching Vector
MPLS Turbo Vector
MTU = 1580
any suggestions?
Silver
Re: LDP over OSPF- tunnel not coming up
check the show mpls ldp interface and check the router id. I think router id not mentioned forcefully and taking it another.
regards
shivlu jain
I went ahead and put the router id in both routers. Here is the message i got:
top-7507#show mpls ldp neigh
Peer LDP Ident: 10.0.0.2:0; Local LDP Ident 10.0.0.1:0
TCP connection: 10.0.0.2.15132 - 10.0.0.1.646
State: Oper; Msgs sent/rcvd: 4522/4527; Downstream
Up time: 2d17h
LDP discovery sources:
Serial1/1/0, Src IP addr: 10.0.0.2
Addresses bound to peer LDP Ident:
10.0.0.2 10.255.0.2
There are still no mpls routes being shared as of yet after i cleared the ospf process.
Silver
please share the outputs of show mpls ldp discovery
regards
shivlu jain
Router A:
top-7507#sh mpls ldp disc
Local LDP Identifier:
10.0.0.1:0
Discovery Sources:
Interfaces:
Serial1/1/0 (ldp): xmit/recv
LDP Id: 10.0.0.2:0; no host route
Router B:
bottom-7507#sh mpls ldp disc
10.0.0.2:0
Discovery Sources:
Interfaces:
LDP Id: 10.0.0.1:0; no host route
Why does it show no host route?
Additionally:
top-7507#sh ip ospf mpls ldp int
Serial1/1/0
Process ID 23532, Area 0
LDP is configured through LDP autoconfig
LDP-IGP Synchronization : Not required
Holddown timer is disabled
Interface is up
It shows the LDP interface is up- but no routes or traffic is going thru.
Silver
It means thats there is no route exists for your ldp identifier. May be you have not configured your loopback forcefully in the glocal for MPLS LDP router id. Please add the given commands in the both routers and clear the LDP neighborship.
mpls ldp router-id loopback0 force
After that run the ldp discovery command and you will find the positive results.
regards
shivlu jain
You might also need to configure network statment for loopback0 under router ospf.
To be sure loopbacks are in area 0.
Here's the logs on the last reboot after the last set of changes- you see that the LDP neighbor relationship AND the MPLS VPN both come up- but it's not passing routes or traffic- not sure why.
When I entered the "mpls ldp router-id loopback0 force " I got: "tag-switching tdp router-id Loopback0 force". Im also noticing that I dont see the "mpls ip" command anywhere in the config- even though it was put in (default?) I feel like there's just a little thing wrong here.
Suggestions? I have the latest config from one of the routers- they are the same on both sides.
*Aug 8 18:08:00 UTC: %PIM-5-DRCHG: VRF VRFB: DR change from neighbor 0.0.0.0 to 10.254.0.2 on interface Loopback1
*Aug 8 18:08:00 UTC: %PIM-5-DRCHG: VRF VRFA: DR change from neighbor 0.0.0.0 to 10.253.0.1 on interface Loopback2
*Aug 8 18:08:11 UTC: %LINK-3-UPDOWN: Interface Serial1/1/0, changed state to up
*Aug 8 18:08:12 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/1/0, changed state to up
*Aug 8 18:08:19 UTC: %OSPF-5-ADJCHG: Process 23532, Nbr 10.0.0.2 on Serial1/1/0 from LOADING to FULL, Loading Done
*Aug 8 18:08:27 UTC: %LDP-5-NBRCHG: LDP Neighbor 10.255.0.2:0 (1) is UP
*Aug 8 18:08:34 UTC: %BGP-5-ADJCHANGE: neighbor 10.255.0.2 vpn vrf VRFA Up
Silver
please configure mpls ip and mpls label protocol ldp in the global mode. mpls ip will not shown not an issue. After that please paste the outputs of show mpls ldp discovery
regards
shivlu jain
Already done on both. Requested output:
10.255.0.1:0
Discovery Sources:
Interfaces:
LDP Id: 10.255.0.2:0
Silver
the output is correct. Please let me know whats the problem you are facing now. Are you getting the proper ldp neighbors.
regards
shivlu jain
Yes- and as I stated previous- the LDP neighbor relationships and the VRF VPNs show to be up. However, they are not passing routes or traffic.
Silver
the setup is like the given below
CE---Router-----Router-----CE
In the config files, I have not seen any MP-iBGP config. Please configure it.
After proper configure run the given command
show ip bgp vpnv4 all summary, you will see the number of routes coming from the specific neighbor.
regards
shivlu jain
What is the MP-iBGP config? I thought that BGP was used only for eBGP to the CE's and OSPF was used for the IGP.
Silver
MP-iBGP is required to foward vrf routes over the service provider cloud. For that you require MP-iBGP. Please configure the given command and run the show ip bgp vpnv4 all summary
Bottom
router bgp 65500
bgp router-id 10.255.0.2
no bgp default ipv4-unicast
neighbor 10.255.0.1 remote-as 65500
neighbor 10.255.0.1 remote-as update-source loopback0
address-family vpnv4
neighbor RR_Routers send-community extended
neighbor 10.255.0.1 activate
neighbor 10.255.0.1 send-community both
address-family ipv4 vrf VRFA
redistribute connected
address-family ipv4 vrf VRFB
top
router bgp 65500
bgp router-id 10.255.0.1
neighbor 10.255.0.2 remote-as 65500
neighbor 10.255.0.2 remote-as update-source loopback0
neighbor 10.255.0.2 activate
neighbor 10.255.0.2 send-community both
regards
shivlu jain
If that's the case- then what is the use of the bgp ldp autoconfig? I want to remove BGP as part of the IGP fabric. Isnt this all supposed to be supported over OSPF?
Silver
I donot know about that command. But ldp autoconfig for IGP is there which enable mpls on all interfaces automatically.
But you need to configure MP-iBGP for communication end to end.
regards
shivlu jain
Hello Greg,
If ping reachability is there between both the router, the please check whether you enable "LDP" on both the routers glocally. If yes and other configs are also OK but still there is no traffic passing even after reachability between routers, then there may also be problem related to IoS of both end PE routers.
I guess this is where Im confused. I am trying to use OSPF LDP Autoconfig to move vrf traffic from router to router and eliminate BGP as an IGP. But Im seeing in the documents that BGP is required on all of the PE's for MP-BGP. What is the optimal way to set this up? Am I going to have to have all of the PE's peer across the network to share this VRF information?
Hello Greg,
U can chck with this command "mpls ldp neighbor " to be exectute globally on far end PE, Hope for the best.
Add this BGP configuration to PE:
(replace xxx by proper AS)
bottom router:
router bgp xxx
no bgp default ipv4
nei iBGP peer-group
nei iBGP remote xxx
nei iBGP update loop 0
nei 10.255.0.1 peer iBGP
add vpnv4
nei 10.255.0.1 activate
add ipv4 vrf VRFA
red conn
add ip44 vrf VPNB
red conn
top router:
router bgp xxx
no bgp default ipv4
nei iBGP peer-group
nei iBGP remote xxx
nei 10.255.0.2 peer iBGP
add vpnv4
nei 10.255.0.2 activate
add ipv4 vrf VRFA
red conn
add ipv4 vrf VPNB
red conn
774
