You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
LDP over T1 serial
Will T1 links be affected by the imposition of labels similar to ethernet frames ?
ie, will MTU be a problem ?
= K
  • MPLS
1 REPLY
Re: LDP over T1 serial
Usually not an issue since it is fairly easy to change the MTU on a serial interface, whereas before increasing the MTU on an Ethernet interface, you need to make sure that the switch supports baby giant frames (slightly bigger than 1500).
Hope this helps,
149
