limitation for RT import
we define different RT value in spoke PE.
I have a question: is there any limitation for the number of route-target import. if I config 50 route-target import under same vrf for all spoke pes, is there problem.
thank you!
  • MPLS
1 REPLY
Re: limitation for RT import
i mean how many entries of route-target import commands i can config under same VRF?
is there any limitation or problem?
is there any limitation for route-target export under same vrf?
thank you!
alcatel engineer said they can only config 20 route-target import entries under same vrf!
thank you!
122
