LMI mismatch in MPLS
We have a MPLS link in layer 2
it is a point to multi point link
in one remote end if we put
show fram-relay lmi it is showing
no.of status enq sent:80352 no of status msg recieved 80079
no of update status recieved 0
no of status timeouts 1100
and it has crc errors and input errors,
can any one guide me.
Purple
Re: LMI mismatch in MPLS
The kinds of errors you are seeing are a result of line conditions - LMI is not the main problem here. I suggest you get your carrier to test the line to see that it runs clean.
Paresh
Mmmm normally LMI involves in Frame Relay network. I assume that you are using Frame Relay connection as a local access to MPLS network. Am I right?
I agree with Paresh. You have to check with your carries to test the line.
jasrine47
http://ciscorouterconfig.blogspot.com/
195
