Match Class Qos GSR
I'm planning QoS to GSR Routers, this moment I have 7500 routers working, and QoS is configured. Now I need to change to GSR and this routers does not support "match class-map ...".
Does anyone help with material to study about QoS in GSR or a solution to this case?
CLRGomes
1 ACCEPTED SOLUTION
Re: Match Class Qos GSR
this might be interesting for you:
"Unified QoS - Locally Generated Packet Prioritization on Cisco 12000 Series Router, Integrated Services Engine (ISE) Line Cards"
http://www.cisco.com/en/US/products/sw/iosswrel/ps1829/products_feature_guide09186a00805e8fc9.html
Regards, Martin
Hi Cassio,
May be you can paste out samples of your Edge & Core QOS Configs.
We would try to help you implement the equivalent on a GSR.
HTH-Cheers,
Swaroop
Hi Swaroop,
Thanks your post.
of course, I'm copying the old configuration, on 7500 router to you see.
class-map match-all CLASS_1_NOTIP
match not protocol ip
match not mpls experimental topmost 4
match not mpls experimental topmost 3
match not mpls experimental topmost 2
match not mpls experimental topmost 1
match not mpls experimental topmost 0
match not protocol clns
class-map match-any CLASS_1
match ip precedence 5
match mpls experimental topmost 5
match ip precedence 6
match mpls experimental topmost 6
match ip precedence 7
match mpls experimental topmost 7
match class-map CLASS_1_NOTIP
class-map match-any CLASS_3
match ip precedence 3
match mpls experimental topmost 3
class-map match-any CLASS_2
match ip precedence 4
match mpls experimental topmost 4
class-map match-any CLASS_4
match ip precedence 2
match mpls experimental topmost 2
policy-map qos_policy
class CLASS_1
priority percent 75
class CLASS_2
bandwidth percent 10
class CLASS_3
class CLASS_4
bandwidth percent 4
class class-default
bandwidth percent 1
I configured a new script to GSR 12400, and it is working only to traffic that is crossing the router GSR. Now I need to configure anything to priorize the traffic generated by itself, for example, telnet or snmp.
Thanks a lot
CLRGomes
prioritizing local traffic is supported. One example config (not from a GSR though) would be:
class-map match-all NMS
match ip precedence internet ! 6
policy-map Test
class NMS
class class-default
fair-queue
random-detect precedence
interface Serial0/0
service-policy output Test
ip local policy route-map LocalIPP6
ip access-list extended NMS
10 permit tcp any any eq telnet
20 permit tcp any eq telnet any
30 permit tcp any any eq ssh
40 permit tcp any eq ssh any
50 permit udp any any eq domain
60 permit udp any any eq tftp
70 permit udp any any eq snmptrap
80 permit udp any eq snmp any
route-map LocalIPP6 permit 10
match ip address NMS
set ip precedence internet
Here I am marking everything locally originated and considered "useful" with IP precedence 6. You could also mark it with experimental bits in the same step, but it should be done automatically (copy IP precedence to mpls exp bits).
Of course you have to adjust the exp bits, ACLs and so on to your environment. The important command for marking local traffic in the config above is: "ip local policy route-map LocalIPP6".
Hope this helps! Please rate all posts.
Regards, Martin
my friend, thanks again,
I know this example, and I use this oin 7500 router, but in GSR 12400 this config is not supported.
look this example:
Router(config)#ip local policy route-map LocalIPP6
% Invalid input detected at '^' marker.
Router(config)#do sh ver
IOS (tm) GS Software (C12KPRP-K4P-M), Version 12.0(32)S4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Wed 16-Aug-06 18:45 by leccese
Image text-base: 0x00010000, data-base: 0x05178000
ROM: System Bootstrap, Version 12.0(20041021:161156) [wdai-v120_30_s 1.15] RELEASE SOFTWARE
BOOTLDR: GS Software (C12KPRP-K4P-M), Version 12.0(32)S4, RELEASE SOFTWARE (fc1)
Router uptime is 1 day, 54 minutes
Uptime for this control processor is 1 day, 54 minutes
System returned to ROM by reload at 16:59:06 UTC Tue Aug 29 2006
System image file is "disk0:c12kprp-k4p-mz.120-32.S4.bin"
cisco 12410/PRP (MPC7450) processor (revision 0x00) with 524288K bytes of memory.
MPC7450 CPU at 665Mhz, Rev 2.1, 256KB L2, 2048KB L3 Cache
Last reset from sw reset
1 Route Processor Card
2 Clock Scheduler Cards
5 Switch Fabric Cards
1 Quad-port Edge-Engine OC3 ATM controller (4 ATM).
1 16-port OC3 POS controller (16 POS).
1 Four Port Gigabit Ethernet/IEEE 802.3z controller (4 GigabitEthernet).
2 Ethernet/IEEE 802.3 interface(s)
4 GigabitEthernet/IEEE 802.3 interface(s)
4 ATM network interface(s)
16 Packet over SONET network interface(s)
2043K bytes of non-volatile configuration memory.
62720K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
65536K bytes of Flash internal SIMM (Sector size 256K).
I think there is another config to mark local traffic, but I'm not sure.
CLRGomes
Regards, Martin
Hi Martin,
I saw this document and solve my problem, I could understand how it works, very well. My QoS is done!
Thanks everybody
CLRGomes.
255
