MPLS/BGP/VRF tie-breaker
hi,
what happens if there are multiple routes with the same route-target are received for a particular FEC? what BGP route selection process (in what order) will a cisco router select (i.e. the best route)?
thanks.
1 ACCEPTED SOLUTION
Re: MPLS/BGP/VRF tie-breaker
an example to highlight what will happen. Assume a PE receives the following routes:
65000:1:10.0.0.0/8 RT 65000:100 next hop 1.1.1.1 locPref 100
65000:1:10.0.0.0/8 RT 65000:100 next hop 2.2.2.2 locPref 200
65000:3:10.0.0.0/8 RT 65000:100 next hop 3.3.3.3
First path selection will be performed for identical VPNv4 prefixes. In the example this means
Then import will take place, i.e. one path per identical VPNv4 prefix will get copied into the VRF, if a route target matches an import statement. Per default import is set to 1. Assuming VRF RD 6500:123 This results in a VRF specific BGP table:
65000:123:10.0.0.0/8 RT 65000:100 next hop 2.2.2.2 locPref 200
65000:123:10.0.0.0/8 RT 65000:100 next hop 3.3.3.3
Now path selection will install the best route into the VRF routing table, in the example this will be:
B 10.0.0.0/8 next hop 2.2.2.2
If you would like to have load sharing in place, then you need to increase import to (at least) 2 and maximum path for iBGP should be at least 2:
router bgp 65000
address-family ipv4 vrf Example
maximum-path ibgp unequal-cost 2 import 2
Hope this helps! Please rate all posts.
Regards, Martin
I believe your question is , what will happen when BGP receives multiple routes to the same destination with the same route-distinguisher. As route-targets wont affect the choice of routes, they only define colors or membership of the route to a certain VPN.
In this case simply the closest IGP path to the next-hop PE which sent the update would be choosen. If this is equal, then it will follow the regular BGP path selection process, begginning from weight -- till the end of steps.
HTH-Cheers,
Swaroop
router bgp 65000
Regards, Martin
329
