Bronze
MPLS Hub & Spoke (metric) help
I'm trying to understand HOW net 172.16.4/24 became preferred via 10.0.0.2 in VRF REG3.
It appears (to me) the decision was made based on lowest METRIC value.
I see the (metric) was set somewhere in the MPLS cloud (I think) but cannot discover how/why the different metric values are being applied to this net. I would like to be able to influence these values as well.
As seen by the command PE3#>sh ip bgp vpnv4 all 172.16.4.0
When 172.16.4/24 is received from 10.0.0.2 (PE2) metric of 30 is applied
When 172.16.4/24 is received from 10.0.0.1 (PE1) metric of 40 is applied
PE3 receives this net in from CE Spoke-4 (WAN4) via eBGP VRF REG4
Since this is a hub and spoke topology, PE3 also receives the net from PE1 and PE2 and in this path is where the metric seems to be getting set.
sh ip bgp vpnv4 vrf nei received-routes
or
sh ip bgp vpnv4 vrf nei adv
run on the different PEs always shows this net with a metric value of 0
Please see my simple topology map of this setup.
Thanks for ANY assistance!
Frank
PE3#sh ip bgp vpnv4 vrf REG3
BGP table version is 252, local router ID is 10.0.0.3
   Network          Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 30:1020 (default for vrf REG3)
*>i0.0.0.0         10.0.0.2                0    100      0 20 i
* i                10.0.0.1                0    100      0 10 i
* i172.16.1.0/24   10.0.0.2                0    100      0 20 10 ?
*>i                10.0.0.1                2    100      0 10 ?
*>i172.16.2.0/24   10.0.0.2                2    100      0 20 ?
* i                10.0.0.1                0    100      0 10 20 ?
* i172.16.3.0/24   10.0.0.2                0    100      0 20 65535 30 ?
* i                10.0.0.1                0    100      0 10 65535 30 ?
*>                 172.17.30.1             0    700      0 30 ?
*>i172.16.4.0/24   10.0.0.2                0    100      0 20 65535 40 ?
* i                10.0.0.1                0    100      0 10 65535 40 ?
* i172.16.10.0/24  10.0.0.2                0    100      0 20 10 i
*>i                10.0.0.1                0    100      0 10 i
----snip---
PE3#sh ip bgp vpnv4 all 172.16.4.0
BGP routing table entry for 10:1:172.16.4.0/24, version 94
Paths: (1 available, best #1, no table)
   Not advertised to any peer   10 65535 40
     10.0.0.1 (metric 40) from 10.0.0.1 (10.0.0.1)
       Origin incomplete, metric 0, localpref 100, valid, internal, best
       Extended Community: RT:10:10
       mpls labels in/out nolabel/248
BGP routing table entry for 20:1:172.16.4.0/24, version 246
   20 65535 40
     10.0.0.2 (metric 30) from 10.0.0.2 (10.0.0.2)
       Extended Community: RT:20:20
       mpls labels in/out nolabel/11413
BGP routing table entry for 30:1020:172.16.4.0/24, version 250
Paths: (2 available, best #1, table REG3)
   Advertised to update-groups:
     17
   20 65535 40, imported path from 20:1:172.16.4.0/24
   10 65535 40, imported path from 10:1:172.16.4.0/24
1 ACCEPTED SOLUTION
Hi Frank,
Path 1 via 10.0.0.2 is better than path 2 via 10.0.0.1 because it has a lower IGP metric to the NEXT_HOP.
In other words for PE3 is easier to get to 10.0.0.2 rather than 10.0.0.1
regards,
Riccardo
Hi Frank,
regards,
Riccardo
Bronze
Re: MPLS Hub & Spoke (metric) help
Hi Richardo,
THANKS!!
Didn't realize (brain freeze) the local IGP (ISIS) played a role here but clearly does.
Totally forgot ISIS this was in use, even through "I" set it up :).
Ahhhh, the learning continues!!
Frank
PE3#sh ip ro
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is not set
       10.0.0.0/8 is variably subnetted, 9 subnets, 2 masks
i L1    10.0.0.1/32 [115/40] via 10.3.0.2, 2d16h, FastEthernet0/1
i L1    10.0.0.2/32 [115/30] via 10.3.0.2, 2d16h, FastEthernet0/1
C        10.0.0.3/32 is directly connected, Loopback0
i L1    10.0.0.4/32 [115/30] via 10.3.0.2, 2d16h, FastEthernet0/1
i L1    10.0.0.5/32 [115/20] via 10.3.0.2, 2d16h, FastEthernet0/1
i L1    10.1.0.0/24 [115/30] via 10.3.0.2, 2d16h, FastEthernet0/1
i L1    10.2.0.0/24 [115/20] via 10.3.0.2, 2d16h, FastEthernet0/1
C        10.3.0.0/24 is directly connected, FastEthernet0/1
L        10.3.0.1/32 is directly connected, FastEthernet0/1
       192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.1.0/24 is directly connected, FastEthernet0/0.6
L        192.168.1.12/32 is directly connected, FastEthernet0/0.6
Hi Frank,
don't worry  brain freezes happen all the times even to experienced engineers.
Riccardo
389
