Community Member
MPLS Monitoring
I am new to MPLS Technology. I have some doubts regarding monitoring the mpls network.
can we measure bandwidth utilization per CoS or per application using netflow?
If so, how can we measure the bandwidth?
can we use IP SLA to measure latency,jitter,packetloss for MPLS networks?
can anyone pls clarify my doubts?
Thanks in advance,
Anju.
Re: MPLS Monitoring
Can you please clarify why do you want to measure application level bw utilization for an end customer.
If you are provising this service as an value add, then alternatively you can enable netflow on the CE and
have it exported to a centralized site for flow level analysis as a part of you managed CPE environment.
Here is a Netflow Solutions Guide to understand more of netflow .
http://www.cisco.com/en/US/products/sw/netmgtsw/ps1964/products_implementation_design_guide09186a00800d6a11.html
You can use VPN Aware IP SLA feature to do the SLA management and tracking for your end customer VPN;s.
Here is the link for this feature.
http://www.cisco.com/en/US/products/ps6566/products_feature_guide09186a0080519a11.html
HTH-Cheers,
Swaroop
Community Member
Re: MPLS Monitoring
Need to generate bw utilization report per cos.
Thanks a lot for ur reply.
293
