Community Member
MPLS MTU and IP MTU on an interface
I am working on a network running MPLS
MPLS MTU 1550 is set under gig interfaces while using show cef interface it shows that IP MTU is 1500
Will this cause some packet drops ?
Isn't it better to have same IP and MPLS MTU or not
thx
Community Member
Re: MPLS MTU and IP MTU on an interface
MPLS mtu means how big a labeled packet can be. so MPLS mtu will be bigger than ip mtu. Each label it has over IP packet wil add 4 bytes.
So its ok to have it, just keep it uniform across the network.
regards,
Gaurav Prakash
It's depending on the MPLS application running on your network as each application (TE, VPN, Qos) add 4 bytes to the header for MPLS aplication labels.
155
