Community Member
mpls network dropping packets
We have some strange behaviour at the moment on our remote servers connected using mpls vpn. When I try and ssh to a centos servers it takes up to 1 minute to get a login prompt. If I ping the server there is no reply for sometimes 30 seconds to a minutes and then replies start happening. It looks like a kind of idle disconnect happening? Does anyone know if this could be anything to do with mpls? or could be just coincidence that this is happening on just our remotes sites using mpls.
Community Member
Re: mpls network dropping packets
Doesn't sound like an MPLS problem. What happens if you ping the default gateway while you are pinging the server?
Community Member
The routing table looks like this
Destination Gateway Genmask Flags Metric Ref Use Iface
192.168.100.0 * 255.255.255.0 U 0 0 0 eth1
192.168.98.0 * 255.255.255.0 U 0 0 0 eth2
192.168.99.0 * 255.255.255.0 U 0 0 0 eth0
169.254.0.0 * 255.255.0.0 U 0 0 0 eth2
default 192.168.100.1 0.0.0.0 UG 0 0 0 eth1
pinging the default gateway at the same time it responds perfectly. Its the remote server that does not respond to ping and then suddenly starts to respond.
--- 192.168.100.1 ping statistics ---
24 packets transmitted, 24 received, 0% packet loss, time 23005ms
rtt min/avg/max/mdev = 0.160/0.238/0.843/0.131 ms, pipe 2
--- 192.168.99.42 ping statistics ---
25 packets transmitted, 6 received, 76% packet loss, time 24006ms
rtt min/avg/max/mdev = 6.419/13.766/50.476/16.417 ms, pipe 2
Community Member
Is there another node in the 192.168.99.x network that you can ping and if so does it look clean like the gateway? If so then you can rule out the MPLS cloud as the issue.
321
